Spaceman007
Tx
I just bought a 2008 Toyota 4Runner SR5 4x4 V6.
Does anyone have any experience towing this?
Do we have to remove fuses???
Unique proceedures to unlock steering? Will it stay unlocked as long as we leave the key in???
What's the best way to hook up the tail lights? Mine has the diode lights.
Any information will be appreciated.
Thanks
JTrac
Oklahoma
Are you talking about towing 4 down? If so, I'm not sure this vehicle is approved for that without some modifications like a transmission pump?????
JimT
Bumpyroad
Virginia
OK, does it have an automatic transmission?
bumpy
goodcruisin
Greenwood, IN
The 2008 Motorhome Magazine Dinghy Guide doesn't even list Toyota trucks. Are you able to put the transfer case in neutral? If you can I'd put the transfer case in neutral, the shifter in neutral and leave the steering wheel unlocked. I also wouldn't want to mess with the LED tail lights. I'd get a set of auxiliary towing lights.
John (USN Ret) and Debbie
The Paw Pack (Freckles, Stinky & Ranger)
'96 Monaco Windsor 36' DP 8.3L Cummins
Ready Brake w/ Demco Excali-bar
'03 Ford Explorer (Toad)
'04 Honda Insight
'04 Volvo S80 AWD
'74 Dart Swinger Drag Car
14' Boat 9.9 Mercury
Nomadac
Columbus, IN
Check your owners manual but I believe that Toyota does not recommend any of their vehicles be towed 4 down unless they have a manual transmission. This being the case you would have to install a transmission pump if available. Otherwise you any transmission failure will not be covered under warranty if it fails.
Arnie
2003 Travel Supreme MH
38KSO1 Cummins ISC 350HP
Car Dolly w/1996 Toyota RAV4 2WD
1963 Pontiac Grand Prix
desertfam
Sunny SO CAL
According to the owner's manual my 2007 Toyota 4runner cannot be towed 4 wheels down. You will have to put it on a trailer or figure out something else.
"Live everyday!"
04' Fleetwood Bounder 32w
02' CRF450R
03' Z400 (Lots of Goodies)
04' Predator 50
04' Predator 90
05' Suzuki JR50
One excellent wife,Two awesomeDesert rats,no problems
John Wayne
Long Beach, Ca
I don't think you need the lube pump BUT you do need the drive shaft disconnect from Remco. Check and see if you have room in the tail light to install separate bulbs & socket for your towing lights.
John & Carol
01 31'Sea View single slide, F53 V-10
96 Toyota 4-Runner auto 4x4 (Remco, M&G brake system)
KF6HCH
Deen
Vancouver, WA
John Wayne wrote: I don't think you need the lube pump BUT you do need the drive shaft disconnect from Remco. Check and see if you have room in the tail light to install separate bulbs & socket for your towing lights. OP says it's a 4 X 4, that means it needs more than just a single driveshaft disconnetc. He'll need two and I don't think Remco makes them for the front. Trailer seems to be the only way since it's not towable four down.
Deen - Vancouver, WA
'02 Dutch Star 4090 (41+', triple slide)
435/1200 ISC Cummins/Banks PowerPak
'08 Honda Civic/dolly
'05 Honda Odyssey/dolly
NRA Benefactor Life Member
FMCA f47302s, Life Member: Good Sam,
Newmar DP Owners Group
51st yr of RV'ing
Bumpyroad
Virginia
I thought that the lube pump was an option to use instead of a drive shaft disconnect so either would work. of course I have read here about lube pumps failing, but I had a drive shaft disconnect on a S-10 PU once and hated it.
bumpy
amxpress
Clayton, NC
Spaceman007,
You CANNOT tow this vehicle 4 down. (it's a 4X4 automatic)
The only way you can dolly it is if you disconnect the rear driveshaft.
You CAN drive it up on a car trailer and pull it that way.
Did you buy this with the intention of towing it?
Nice vehicle to drive, terrible vehicle to tow.
2007 Dodge RAM 2500 Quad Cab w/6.7 Cummins
2008 Palamino Sabre 31RKTS
Reese 15K Pro Series manual slide
Prodigy
Firestone Air Bags
Travel in peace...leave the M-I-L at home.
