Todd Barney
Atlanta area, GA, USA
Now I need a better place for the hitch head. Though normally it would have the ball cover over all that grease.
2006 Maxlite 30BHS
Maxlite Photos
Large: 2003 Dodge Ram 2500 Quadcab 4x4 V-10 5spd manual 3.73
Equal-i-zer, Prodigy
Medium: '03 MPV ES
Small: '91 Miata
Pad the walls, we got 8-yr-old twins in here!
kckettridge
Northern California
I put plastic trash can liners over the greasy ends and set them in the bed of my truck when we are camping. The plastic bags keep the grease away from the dog and the rest of whatever we need to put back there when we go out on excursions. At home, I'm very fortunate that I have a friend who has 10 acres and an 8000 sq. ft. shop on his property that I'm able to store my trailer on and all the camping gear in one corner of the shop. If the ceiling and roll up door in the shop was higher, I would store the trailer inside. But it beats paying $80 - $100 per month at a public storage place.
planter8
Utica, MI
I like the gun case idea...THANK YOU!
Planter8
Sunset Trail ST30BH
Ford Econoline E-150 wagon 5.4L V8 3.55 axle
Equal-I-zer hitch
MDM8770
Las Vegas, NV
I purchased a holder from the Internet which are two short tubes that mount vertically on the front of the trailer frame. The bars face down into the tubes and are kept clean and held in place (above the ground) this also leave room in the storage compartment and does make the mess. I will try and post a picture of the setup. It works very well.
"2 Far From Retirement 2 Wait to Travel!"
Marc, Jane, Morgan and Marcus (The Crew)
07 F150 Supercrew & 06 Rockwood 8318SS
RVing since 1990 but this is the 1st TT
martipr
Haltom City, Texas
The rifle case sounds great to me. I have been covering the greasy ends with gallon size zip-lock bags and placing them in the pass through. Somewhere I saw a pic of a rifle case someone used and he also stored his friction sway control in it.
Old Navy Chief (AOC) Retired Aircraft Mechanic/Inspector
2007 29' 27FBV Trail Bay V Series
2007 Dodge Ram 1500 Mega Cab 5.7 V8
Reese Strait-Line Dual Cam Hitch
dkhender
VA
MDM8770 - I'd be interested to know more details about what you purchased and to see pics. I've been looking for something similar.
jc1843
So Calif
I keep mine on the tongue right behind the propane tank. They cross so I can determine which one is left/right. I slip a baggie over the greasy end and dispose of it when I reinstall them. Also keeps the dirt off!
WRBRO&DI
OHIO
Not liking the idea of leaving them outside or unattended, I slip an old heavy sock over the nasty end and lay them in the front storage compartment. This keeps things clean.
Nascar24
Blackstone Valley, Massachusetts
Hi
I welded some rectangular tubing to the inside of my trailer tongue in the vertical position, I also welded a piece of band stock across the bottom, I insert the bar ends into the tubing and the stand up behind my propane tanks when not in use. For the bal mount I welded a small 2' X 2" box tube to the underside of the trailer tongue, I just slip the hitch goesinta into the box tubing and pin lock it. Everything stays nice and neat right where I need them when not in use.
I would be happy to post a picture but the trailer is buried with four snow plows in front of it so I can't get a clear shot for a photo.
Good Luck and Happy Trails
2007 Dodge 3500 4X4 MC,SRW,CTD EB
2004 Citation 29NP
Equal-i-Zer
Yamaha EF2800i
Nascar24 A lengend in my own mind, A Scary thought in someone else's!
o2bpadln
Richlands, NC
I usually use mind to hold down out door mat while camping placing one on a corner. When not camping the stay in tool box in truck bed.
o2bpadln
03 Chevy 1500 5.3 Towing Package
04 Rockwood 2602
Have road will travel. Have water will paddle.
