RV.Net Open Roads Forum: Tech Issues: mildew problems
 > mildew problems
geniebnee
rock city, il.
Posted: 02/26/08 08:00am Link  |  Quote  |  Print  |  Notify Moderator
i recently noticed a strong mildew odor when i turned the air condioner on. we are currently staying at a campground in the crystal river,florida area. any suggestions as to possible causes and recommendations to remove odor? i am in a 2000 challenger by damon fifth wheel.
* This post was edited 02/26/08 08:23am by geniebnee *
RVSnowbird
OR-NV-AZ-OR
Posted: 02/26/08 08:42am Link  |  Quote  |  Print  |  Notify Moderator
moved from Forum Technical Support to the Tech Issues forum
geniebnee, please check your Private Messages for information you need to know about the forums including an explanation of this move.
RVSnowbird
have you checked out the new RV.net Blogs yet?
Deceased 2/28/08 RIP
donn0128
Pronounced Ore-gun
Posted: 02/26/08 01:27pm Link  |  Quote  |  Print  |  Notify Moderator
Water pooling, dirt are two possible answers. Find the source of the problem, fix it and then bleach everything in site to get rid of the spores.
Donn
Nolan
Full-timing
Posted: 02/27/08 07:21am Link  |  Quote  |  Print  |  Notify Moderator
Yup. Had the same problem here in Lake Panasoffkee, Florida. I removed the shroud, the wife and I removed around 25 screws to get to the evaporator coils and drain pan. Cleaned all the dirt and dust out. Sprayed a 50% water 50% bleach mixture on everything. Closed it back up. It didn't do a thing. Next time we used the A/C, had the mold smell. I posted on the NuWa trailer forum site about it and was told to buy BG Frigi-Fresh or BG Frigi-Clean. Made mostly for using in cars and trucks A/Cs. We got some and started using it. Sprayed the coils first and let set for a few days then when ever the A/C would kick on would spray the stuff through the intake vent. Also had one cool morning where we turned on the heat pump and I think that helped too. No more mold smell.
Nolan and JoAnn
2000 Kenworth T600. (The Little Blue Truck)
2004 NuWa Hitchhiker Champagne 33LKTG
2003 Kawasaki Nomad. The Cow. (mine)
2004 Harley Road King. The Hog. (hers)
http://community.webshots.com/user/2ontheroad
 > mildew problems
