RV.Net Open Roads Forum: Tech Issues: ceilling stains
 > ceilling stains
garyl44
coldwater Mich. U.S.A.
Posted: 02/27/08 12:35pm Link  |  Quote  |  Print  |  Notify Moderator
Had 4 ceilling stains on my class A from roof leacking under new custom rv cover. Was wondering how to remove large stains from ceilling. It is still pretty cold here in Mich, will have to wait untill it warms up a little. I have no heat in motor home. Thank you very much for information. Garyl44
RVSnowbird
OR-NV-AZ-OR
Posted: 02/27/08 12:38pm Link  |  Quote  |  Print  |  Notify Moderator
moved from Forum Technical Support to the Tech Issues forum
garyl44, please check your Private Messages for information you need to know about the forums including an explanation of this move.
RVSnowbird
have you checked out the new RV.net Blogs yet?
Deceased 2/28/08 RIP
RV my private jet
Portland,OR
Posted: 02/27/08 12:44pm Link  |  Quote  |  Print  |  Notify Moderator
I have been very succesful with a solution of 1:5 bleach to water in a spray bottle. Mist it on and let sit. Be careful to cover anything around that you don't want discolored. Go back in an hour to find the stains disappearing. Reapply a few times until they are no longer visible. There is a product out there that I have read about but the name escapes me and apparently it is just an overpriced chlorine based product anyway.
"...sometimes your the pigeon, other times the statue."
Gary.
Yukon, OK
Posted: 02/27/08 02:38pm Link  |  Quote  |  Print  |  Notify Moderator
I hate to say this, but you better find the leaks before you worry about the stains, or the stains will just be back and bigger!
rmmpe
Milford, PA
Posted: 02/28/08 04:39am Link  |  Quote  |  Print  |  Notify Moderator
And make sure you spray over the Chlorine after the stain disappears with white Vinegar to neautralize the Chlorine.
Roads Scholar
Carry on, regardless
Alpine 36SDS
Cummins 330 ISC
Allison 3060
topflite51
In The Desert of Nevada
Posted: 02/28/08 08:53am Link  |  Quote  |  Print  |  Notify Moderator
Yes, that would be the first thing. No matter what you use to remove the stain, best test it in an inconspicuous place first, as some cleaners do more harm than good. I personally use an Oxygen cleaner (clorine free) powder, it is in with the laundry detergent area of most grocery stores. It has done the job for me.
David
Just rolling along enjoying life
 > ceilling stains
