RV.Net Open Roads Forum: Travel Trailers: equal-i-zer questions
 > equal-i-zer questions
kwmjd
michigan
Posted: 03/01/08 10:11pm Link  |  Quote  |  Print  |  Notify Moderator
I'm about to order the equal-i-zer hitch. I was just wondering if there is an advantage to getting the 1200lbs bars over the 1000lbs bars. My new trailer will have a dry hitch weight of 750lbs. thanks, keith
rexlion
Tulsa OK
Posted: 03/01/08 10:16pm Link  |  Quote  |  Print  |  Notify Moderator
If you ever trade for a different TT with heavier tongue weight, you'll be equipped. Other than that, no advantage that I know of.
Mike & Sherry
2000 Mercury Mountaineer
2008 Toyota Highlander
2005 Rockwood 2304s
= Equal-i-zer hitch =
turbopilot51
Ridgefield, WA
Posted: 03/02/08 12:03am Link  |  Quote  |  Print  |  Notify Moderator
My 31' trailer has a hitch weight of almost 900lbs. I am using the 10,000lb equal-i-zer hitch with no problems. Even in the cross winds!
Mike Schriber
San Diego, CA
Posted: 03/02/08 01:07am Link  |  Quote  |  Print  |  Notify Moderator
You'll be best off getting bars matched as closely to your tongue weight as possible. Too much bar will make the ride bouncy and cause the rig to porpoise.
Mike
2005 Chevrolet Suburban K2500 LT (8.1 liter with 4.10 gears)
2004 Starcraft Homestead 29BHS (16,000 pounds combined)
Twin Honda EU2000i Generators - 12' Porta-Bote
Prodigy / Putnam XDR / Equal-i-zer
SoCal Family Campers
sheepherd
Northern Indiana
Posted: 03/02/08 07:28am Link  |  Quote  |  Print  |  Notify Moderator
Call Equalizer 1-800-478-5578. They were a great help to me when I had to make that same decision last week.
Pat
‘03 Ford 350 PSD Lariat 4X4 25,400 miles
‘08 Jayco Feather 25F 230 miles
dodge guy
Chicago, western subs.
Posted: 03/02/08 09:30am Link  |  Quote  |  Print  |  Notify Moderator
I`de go with the 1000lb bars! like mike said to much bar is not a good thing! and could cause loss of traction in sever situations.
Go with what matches the tongue weight. my dealer swapped my 800lb bars for 1200lb bars when I picked up our new, heavier TT and didn`t cost extra.
Wife kim
Son brandon 7yrs
Daughter marissa 6yrs
Dog shadow
07 Cherokee 32B
02 Excursion 4X4 V-10 4.30 gear
Reese HP dualcam,Prodigy brake controller,
Air lift air bags.
Better to have a bad day of
camping than a good day at work!
Chuck&Gail
In the Colorado Mountains
Posted: 03/02/08 10:03am Link  |  Quote  |  Print  |  Notify Moderator
PLEASE NOTE DRY HITCH WEIGHT HAS NO MEANING!!!!
You need to know actual hitch weight when fully loaded, and that needs to be about 13% of the fully loaded TT weight. If you do not know those numbers, ASSUME 13% OF TT GVWR for tongue weight. Then get bars for that weight.
You can indeed use bars that are oversized, but the ride will be worse, and trailer contents more apt to bounce all over. Bars act as springs.
Chuck
Wonderful Wife
Lovely German Shepherd.
1999 Mercedes ML320 TV
2003 Wanderer 187TB Toybox (3620# UVW, 4800# loaded)
Not yet camped in Hawaii, 2 Canada Provinces, & 2 Territories.
subourbon
Huntsville, AL
Posted: 03/02/08 10:51am Link  |  Quote  |  Print  |  Notify Moderator
Go to equalizerhitch.com. Select Tech Specs, Select your max trailer wt. and tongue wt. They will tell you the equalizer system with bars that you should purchase. Most likely if your max trailer wt is under 10,000 lbs and your tongue wt. is under 1000 lbs you will purchase the 10,000 lb with 1000 lb bar set (part no. 90-00-10000). Toggle down the page and enter the information required to pick the right hitch shank.
2007 Chev. Silverado CrewCab 4x4
6.0L Vortex Max
3.73 Rear Axle Ratio
Prodigy Brake Control
Equalizer Hitch
Champion 4000/3500 30A RV Gen.
Garmin 7200 GPS
2008 31E Jayco Feather LGT
UVW6225 GVW7850
ROBINS NEST
ArcticFox&Cats
Utah
Posted: 03/02/08 10:58am Link  |  Quote  |  Print  |  Notify Moderator
My $.02/cents. This is one time that over-kill is NOT in your best interest. One needs the "flexing" abilities in the equalizer....or as they have said, you will get a really harsh ride, for TV and TT.
'07 Nash Hardside 19B
'07 2500 Chev D/A SB, CC, 4x4, 3.73s, 45/gal TrnsfFlow
Equalizer, BrakeSmart, Enkay Mudflaps
'07 Arctic Cat 400cc ATV
"A bird is a bird. A fish is a fish. A Dog is a Person."
Seymour_family55
Greer, South Carolina
Posted: 03/02/08 12:33pm Link  |  Quote  |  Print  |  Notify Moderator
If the bars are a LITTLE more than you need, thats ok
but if the bars are WAY more than you need-that can cause problems
I say stick with 1000 as long as you don't put too much weight in the front
Buzzy & Lynn
Jarred(16)
Dixie(The Black Lab)
2007 Palomino Puma 29FQS
2003 Dodge Ram 2500 Quad Cab, Long Bed, CTD, Auto (new to us)
camping pictures
