BRADY BUNCH
TN
My brother has a 2005 FR Travel Trailer and neither of the two slides will open. He manually cranked out the main slide so he could check voltage. He gets 6 volts to the switch on the wall, all fuse blocks show 13volts. He gets voltage at the motor when he pushes the switch. He can't check the rear as he can't get to the manual crank. Anyone have any ideas or suggestions? Is the voltage correct at the Wall? He is plugged up the shore power and its 30amp service on the TT.
JFG
TN
Since neither slide works and voltage is present, it sounds like a lock out device is keeping the slides from activating. On my MH, if the ignition is on or trans not in "N", the slides will not operate.
Fred
BRADY BUNCH
TN
This is on a travel Trailer not a MH
bwtrump
Still no discounts for
Check the circuit breakers that are "resettable" should be mounted near the batteries or near the pump for the slide. Usually black, mounted 2-3 in a row. The one blown should have a tab sticking out of the side to let you know it has tripped. Push the tab back in to reset.
Bryan and Peg, 3 kids IAFF Local 795
2008 Wildcat 28 RKBS
2003 Dodge 2500 quad cab Cummins 5.9HO
Husky 16K slider
Alex--Great Dane
Bull Mastiff--Sebastian Pierce
dougrainer
Carrolton
The voltage should be 12 volts thru out. FR does not use any 6 volt circuits on their Trailers. What is the voltage at the motor? Has he checked that? Doug
Wherever I happen to park
If he gets voltage to the motor, but the motor does not run, then either 1: The motor is bad or 2: the manual clutch used to enable manual operation is in the "Released" position. (if such a clutch exists)
If he gets voltage to the motor and the motor runs but the slide does not move, then there is a shear pin or bolt sheared or a gear is broken.
And that is the list of possible conditions
Oh, one additional condition here where I"m at
Moisture between the seal and the wall has frozen and the slide is literally FROZEN in place, this is not, of course, the condition once he's manually cranked it out.. But it is a problem I have in my "house" A well placed foot "Assists" the slide in sliding in my case
BRADY BUNCH
TN
THANKS FOR ALL THE RESPONSES!
This is what he found out ..Quote "It was my battery. Wouldn't work hooked to shore line with a dead battery. Very strange. I had it on the charger all day and it looks like I will have to replace it."
I wouldnt have thought that would have affected the slides but I do know when you have a bad battery that sure can make thing go haywire.
