RV.Net Open Roads Forum: 1/2 Ton TV Pulling Sprinter 311 or Jayco G2 32BHDS
 > 1/2 Ton TV Pulling Sprinter 311 or Jayco G2 32BHDS
centerice
Ontario
Posted: 03/02/08 04:27pm Link  |  Quote  |  Print  |  Notify Moderator
I would like to hear from people with these trailers I mention above, any of you pulling them with a 1/2, like the Ford F150 or Dodge Ram 1500, I would like to hear what your set up is too, 5.7L V8 with 3.73 axle ratio, towing packages and what kind of fuel economy are you getting driving in town or hiway without trailer and same with trailer.....curious too see, I am ready to buy both truck and trailer, but I am worried about the TV size, and I really don't think I can afford to go to a 3/4 ton......thanks
browns329
New Jersey
Posted: 03/02/08 04:38pm Link  |  Quote  |  Print  |  Notify Moderator
I'm sure you will get some expert replies here regarding GVW, tongue weight, etc., but based on my feeble knowledge, that TT is too much for any 1/2 ton TV. If that size TT will best fit your needs, I would look for a used 3/4 ton TV that you can afford to tow it.
2003 GMC Yukon XL 2500 (3/4 ton), SLT, 4x4, 8.1L, Autoride, 4.10 gears
Putnam XDR, Equalizer 1400#, Tekonsha P3
2008 Jayco Eagle 314BHDS (Bunk house double slide)
Me, DW, 2 DD, lots of pets
Lucas874
Kingston, NH
Posted: 03/02/08 04:42pm Link  |  Quote  |  Print  |  Notify Moderator
The way I see it, you have two choices: 1. Buy a bigger truck 2. Look for a smaller trailer.
2007 Jayco Jayflight 29BHS
2002 Chevy Silverado 2500HD
Hornet28BHDS
Parker, PA
Definately find a good used 3/4 ton TV. You won't be happy with a 1/2 ton's performance while pulling that size TT.
2006 Hornet 28BHDS-Bunk House, Dual Slides
2006 Dodge Ram 2500 HD
5.7L Hemi, Factory Towing Package
Reese Brake Controller, WD Hitch and Sway Bar
Life is short, why not spend it in an RV!
SPRING HAS SPRUNG!
You can't take the Fisherman out of this Camper
Ontario, Canada
Posted: 03/02/08 05:14pm Link  |  Quote  |  Print  |  Notify Moderator
I pull my 29 footer with a 3/4 ton truck. I wouldn't be at all happy with a half ton. I need the power of the 6 litre engine.. anything less would be a huge disappointment!
1960's: Tents.. 1970's: Soft top & Hard top P/U.. 1980's: 17' RV.. 1990's: 24' RV.. 2000's: FINALLY... 2002 Cougar 276EFS; 2002 GMC 2500HD Ext Cab 4x4; (Nfld/Labrador-Yukon/NWT/Alaska-Gaspe', Que./Florida!!)
centerice
Ontario
Posted: 03/02/08 05:46pm Link  |  Quote  |  Print  |  Notify Moderator
Thanks for the good advice, I was worried it would be too much trailer for the truck...thanks again........this is a great forum I must say, can't beleive all the info and tips and advice....
skipnchar
Topeka Kansas USA
Posted: 03/02/08 06:39pm Link  |  Quote  |  Print  |  Notify Moderator
You're looking at a tongue weight (DRY) of over 1,000 lb. so loaded would likely be close to 1500 lb. The F-150 would do it provided you get the HD option with either the 2500 lb. payload (super cab) or 3,050 lb. payload with the regular cab. I don't know of any half ton Dodge that would handle that much tongue weight and the new Toyota won't sell the max payload option with the trailer tow package. GM has an HD 1500 that would do it but it's actually a 3/4 ton truck with limited engine options (6.0 is the biggest you can get with it). The GM 6.0 is about the same HP and torque as the Ford 5.4 and either would do the job but bigger would of course do it better. You'd CERTAINLY have more options with a 3/4 ton. Good luck / Skip
kaydeejay
SE Michigan, USA
Posted: 03/02/08 06:46pm Link  |  Quote  |  Print  |  Notify Moderator
Just so you understand where everyone is coming from....
Take the Jayco 32BHDS:
Unloaded weight (UVR) 7855# (No battery, propane, water or options (like awning and TV))
Gross Vehicle Weight rating (GVWR) 9750#.
IMHO you would be a lot closer to GVWR than UVR
Tongue weight (at 13%) would be around 1265#. It may be as high as 1500#. (Depends on the tongue weight ratio)
Now go and check the payload specs for the trucks you are looking at:
You need to add passengers, hitch, tools and anything else in the truck to the 1265#. Is that under the max?
As an alternative, deduct the "loaded for travel" weight of the truck from its Gross Vehicle Weight rating (GVWR). That is your remaining payload. Do you have 1265# left? Probably not!
You then need to add 9750# to the LOADED weight of the truck.
Is that under the Gross Combination Weight rating (GCWR)? Probably not!
Like the others, I'll suggest that is too much trailer for most 1/2 tons but hopefully you now understand why.
Keith J, Retired from GM Engineering
2005 GMC Sierra 2500HD SLE 2WD/CC/SB/DA.
1999 Sunnybrook 27RKFS Fiver
Bilsteins, Line-X, Westin steps, Prodigy, Retrax, 16K Superglide, 5th-Airborne pin-box, Multi-vex mirrors.
d schmincke
Manchester md
Posted: 03/02/08 07:13pm Link  |  Quote  |  Print  |  Notify Moderator
i tow a keystone cougar 304bhs with a toyota tundra does fine
turbopilot51
Ridgefield, WA
Posted: 03/02/08 08:30pm Link  |  Quote  |  Print  |  Notify Moderator
I tow a 3141 BHDS Keystone with my Dodge 2500 diesel. I could not imagine towing with anythngn less!
