RV.Net Open Roads Forum: Technology Corner: Did I miss something?
 > Did I miss something?
wild bill
Mira Loma, Ca. USA
Posted: 03/02/08 08:45pm Link  |  Quote  |  Print  |  Notify Moderator
Just had a King Dome sat dish installed on my fiver....Worked great in my driveway {So. Cal}. I have Dish Network and it works off two satellites.....Switches form one to the other just fine....Went to Laughlin Nv..for the weekend and the unit would only lock onto one satellite. Got home and the unit worked fine in my driveway? Did I miss something or do something wrong.....Clear view of the sky form RV park in Laughlin....Thanks
05 Dodge 3500 Q-Cab,GearVendor 8 Sp,PacBrake,Banks intercooler & intake,TST R49,Transferflow 70 tank,TrailerSaver Hitch,05 Raptor 3612,Second AC, solar 6 battery sys Xantrex 3000,Sand Rail 02 Nightrain,ST4s KLR650,ll00RT,AOPA BMWMOA,EAA,HOG,TDR,NRA,FCSA
pulsar
Lewisville, NC
Posted: 03/02/08 09:07pm Link  |  Quote  |  Print  |  Notify Moderator
What programming were you not getting on that second satellite. Could it be that you were looking for your local (home) channels. Those channels are "spot beamed." Once you are out of the "spot", you can no longer receive them.
Tom
2002 Adventurer 32V - Workhorse chassis
1998 CRV toad - manual transmission
Have you seen the RV.Net Blogs? You can subscribe at Blog.RV.Net
Wherever I happen to park
Posted: 03/03/08 08:16am Link  |  Quote  |  Print  |  Notify Moderator
Since you said it would only lock onto one sat.. Is it possible that SOMETHING was in your way? I mean, I know Laughlin is not well forested like I have here (I can't lock on either satellite) but there might have been a lamp post in the way
Posted: 03/03/08 08:27am Link  |  Quote  |  Print  |  Notify Moderator
Is it possible that something was in the way of the 2nd bird, I mean, here in well forested Michigan I can't see either DISH bird from where I keep my rig, I know trees are not as big a problem in Laughlin, but even a well placed lamp post can block you if it's close enough
Posted: 03/03/08 08:28am Link  |  Quote  |  Print  |  Notify Moderator
Enjoying the Lagniappe
Destin,FL,US
Posted: 03/03/08 11:00am Link  |  Quote  |  Print  |  Notify Moderator
I have a different make of dish that does the same thing. Sometimes you have to do checkswitch. Call King Dome and they will walk you through it.
wild bill
Mira Loma, Ca. USA
Posted: 03/03/08 09:47pm Link  |  Quote  |  Print  |  Notify Moderator
Thanks for the replies....Yes I was trying to get some of my local channels that may not be available in other locations. I did not know this....so again thanks for the help.
