pmfinnegan2
S.E. Michigan
When topping off your battery you used distilled water correct? Just wanted to make sure.
pmfinnegan2
1998 Dodge Ram 1500 Sport
318 5.2L V-8, 3.92 Rear end
HD Transmission Cooler
2006 Max-Lite 24RS
Equalizer Hitch, Prodigy Brake Controller
Wife, 6 year old Daughter, and 2 year old son
trop-a-cal
Palm Coast Fl
Yes, and charge it up after adding or it could go flat. Usually add every month while in use. I use a turkey baster. Put on rubber gloves if you have them to avoid acid burns. Fill to inside rings not above.
orange99
Napa , CA
Yes, better safe than sorry (water to acid not acid to water)
On the road to adventure
thecaptain
Belleville,Mi.48111 USA
Yes use only distilled water.
Ken/Ellen(RET)
2000 F250 Superduty
7.3psd/Banksbrake/Smartlock/Trans command/3.73gear/Edge EZ module
2002/29ft-Terry 5er:
Take life one day at a time.
Hurricaner
Hurricane Utah
Top off a fully charged battery only. A fully charged battery will have a higher level than a partially discharged one. If the battery is discharged just make sure there is enough water to cover the plates.
Sam
Sam & Kari
Hurricane, Utah
2004 34' Damon Challenger 315
bldrbuck
Boulder, Colorado
This is a rather long discussion on batteries but has a lot of good information. Just skim over the parts that don't apply to you.The 12volt Side of Life
Trojan Battery Company - Charging
edited 03/04/08 06:46am by bldrbuck *
93 Ford F350 Turbo Diesel, DRW, Crew Cab. PullRite Hitch. 90 Nomad 28' 5er, 375 Watts Solar, 2800 Watt Yamaha Generator, 1750 Watt Inverter, 4 Trogan T105 Batteries, Spare tire and wheel and folding ladder. Me, wife and 2 spoiled Maltise furkids.
erpa
South Central,East Coast. FL
That is correct!!
Eric & Pat
2002 Dolphin 5356
W22 Chassis
1999 Saturn SL1
2002 Trip FL to Alaska & back to FL Photos Link below
http://community.webshots.com/user/erpafl1020
Other Trip Pictures;
http://s125.photobucket.com/albums/p80/erpafl1020/
Matthew_B
The boonies near Dallas, Oregon
I bought a Nalgene bottle to make filling batteries easy:
It usually doesn't take much water, and with these bottles, I can easily control how much I add without spilling any.
Deen
Vancouver, WA
trop-a-cal wrote: Fill to inside rings not above. According to MH magazine this month you don't fill to the ring, go about 1/8" below it.
However, since I have 4oz of mineral oil in each cell (cuts down on amount of water used and corrosion in the battery compartment) I do fill till the oil touches the ring.
Also, some "distilled water" is actually just filterd city water and probably still contains minerals. I look for "steam distilled" since that's what REAL distilled water is.
Deen - Vancouver, WA
'02 Dutch Star 4090 (41+', triple slide)
435/1200 ISC Cummins/Banks PowerPak
'08 Honda Civic/dolly
'05 Honda Odyssey/dolly
NRA Benefactor Life Member
FMCA f47302s, Life Member: Good Sam,
Newmar DP Owners Group
51st yr of RV'ing
Gale Hawkins
Murray, KY
Remember batteries not fully charged will look low when they are not. Water should be over the plates but 1/4" below the BOTTOM of the filler opening. Most people overfill other wise there is not much chance of rust and a mess in the batttery area.
