RV.Net Open Roads Forum: Toy Haulers: Compression brake for 03 Dodge 3500 Cummins
Search only in Toy Haulers
Open Roads Forum  >  Toy Haulers  >  Modifications & Accessories
 > Compression brake for 03 Dodge 3500 Cummins
DAKOTAT76
Currently Alaska, Moving soon to the Midwest!
Posted: 03/04/08 12:19am Link  |  Quote  |  Print  |  Notify Moderator
I checked with a Dodge dealer up here in Alaska and they informed me that they do not sell or install compression brakes for my rig, they only go back to 05 and to 08.
anyway my question is have any of you on here had a compression brake installed by a Cummins dealer which is what I have been told I need to do.
and if so what was the out the door cost (installed and ready to go)
I will need it since I will be moving from Alaska to the Mid west this summer and towing my rather large 3612DS Key performance Raptor.
traveling some of the Alaska hiway, then south to Wa state, from there on to the mid west...
Long trip and I dont need to burn out my brakes enroute..
2003 DODGE 3500 DRW 4X4
Bombardier Traxter ATV
Yamaha Grizzly
Arctic Cat 90
Hunting-Fishing-Riding-Off-Roading
Outdoor-Family = Fun Always!
2007 Keystone Raptor 3612DS
http://pg.photos.yahoo.com/ph/dakotat76/my_photos
(ATV/RV/Off Roading Adventures)
magilla70
upstate NY
Posted: 03/04/08 04:09am Link  |  Quote  |  Print  |  Notify Moderator
I am not sure about a compression or engine brake, but I have a Pacbrake exhaust brake on my 03. It works awesome, greatly reducing the use of my service brakes. www.pacbrake.com I have the PXRB on mine. Dodge sells a Jacobs exhaust brake for our trucks but it is vacuum operated and requires a vacuum pump added to the motor with a longer accessory belt. The Pacbrake is air pressure operated and has a more reliable air compressor to run it.
2005 Keystone Raptor 3512SS
2003 Dodge Ram 3500 Laramie QC DRW HO CTD
2003 Polaris Sportsman 700
2005 Honda VTX 1800F Spec II (mine)
2005 Honda VTX 1300C (hers)
2005 Honda CBR600RR track bike (w/Ohlins goodies!)
dryman
texas
Posted: 03/04/08 06:56am Link  |  Quote  |  Print  |  Notify Moderator
I see you own a Raptor and live in a cold area! and I have a question,I just purchased an 07 and wondered about how well they are insulated? Do you find it hard to heat and keep warm?
JIMNLIN
Big Cabin, OK
Posted: 03/04/08 06:58am Link  |  Quote  |  Print  |  Notify Moderator
T76
My '03 2500 Dodge/Cummins has a Jacobs exhaust brake that my Dodge Business Link dealer installed when the truck was new. They have lots of commercial customes that use the exhaust brake and have experienced diesel mechanics. I would look at the Pacbrake PRXB which has more braking at a lower rpm (1500-1800) due to their new design. They all have about the same braking HP at max rpms. A advantage of the Pacbrake is it uses a air pump. The Pacbrake operates from air pressure and that may come in handy for other uses. The Jacobs on my '03 has a vaccum pump that operates the brake. The vaccum pump is added and takes a much longer serpentine belt (80 bucks). The truck has over 90k and zero problems with the Jacobs and is covered by a Dodge warranty. Dodge doesn't warranty the Pacbrake for use on the drivetrain or the Cummins. If your out of warranty look at the Pacbrake for a much simpler setup. Either way get a exhaust brake installed and you will wonder why you didn't have it installed sooner.
Never heard of a compression brake for our Dodge/Cummins.
JIM
'03 2500 Dodge/Cummins HO 3.73 6 speed manual Jacobs
'97 Park Avanue 28' with two slides
magilla70
upstate NY
Posted: 03/04/08 07:29am Link  |  Quote  |  Print  |  Notify Moderator
The dealer dosen't have a jacobs listing for your truck because it must be an automatic (this dawned on me as I drove to the gym this am). If so you will need a electronic box to lock the transmission while the brake is on. If you order a pacbrake for an auto it will come with a transmission controller.
I have the PXRB....never again will I tow without one!!!
DAKOTAT76
Posted: 03/04/08 09:22am Link  |  Quote  |  Print  |  Notify Moderator
Something I forgot to mention, my truck is equipped with the 6 speed standard trans.
as I have been searching on the net, everything I have seen thus far is for automatic transmissions, am I missing something here?
bjbear
Cold Lake, AB, Can
Posted: 03/04/08 09:40am Link  |  Quote  |  Print  |  Notify Moderator
I second the Pacbrake PXRB. I comes with a controller that will control the lock-up on the 48RE transmission. Works well.
2003 Dodge 3500 DRW HO with:
Edge Juice
Banks Ram Air, Pac-Brake, Exhaust
ATS 5-star Torq Conv
ATS Hi-Perf 48RE Trans with Billet Input Shaft
Trailersaver T3 Hitch
2005 Komfort Karryall - 36 foot
2006 HD Electra-Glide FTHCI
2 - Kaw Brute 650i Quads
magilla70
upstate NY
Posted: 03/04/08 10:17am Link  |  Quote  |  Print  |  Notify Moderator
Here is a link for the PXRB application guide, there is a standard trans option for your 03 there. Dodge PXRB
coolbreeze01
Redding, Ca
Posted: 03/04/08 10:52am Link  |  Quote  |  Print  |  Notify Moderator
I ran a BD exhaust brake on a CTD for 14 years. No problems and no maintenance. Worth a look.
2008 Dodge 3500 CTD LB SRW 4X4 6-Speed Auto
P3 Blue Ox Sway Pro
2007 Komfort 212
DAKOTAT76
Posted: 03/04/08 08:33pm Link  |  Quote  |  Print  |  Notify Moderator
I appreciate everyone's input into this, I do have the problem solved since I am going with the Cummnins exhaust brake, going to get it installed this week at Northwest Cummins here in Anchorage, AK
Thanks
Kip
