RV.Net Open Roads Forum: Truck Campers: Onan 2.5 Generator
 > Onan 2.5 Generator
Moomba2002
Sebastopol, CA
Posted: 03/04/08 03:33pm Link  |  Quote  |  Print  |  Notify Moderator
The Onan in my Arctic Fox 1150 started surging this weekend while attending the Nascar race in Las Vegas. If running to charge the batteries it will do it, and if I put a larger load on it like the air conditioner or the microwave it will smooth out. If anyone has had this problem and was able to resolve it (without taking it out and adding a Honda 2000)I would appreciate it. Thanks for the help this forum has some great ideas on it. Sean
1999 Ford F350 DRW 4X4 PSD 6spd.
Banks Stinger Package
Fords upgraded Air Intake System
ExtremeAire 150 PSI 100% Duty Cyle on board air w/4gal. tank
Air Bags & Rancho 9000's
2003 Arctic Fox 1150 loaded except solor
wing464
Any where the job takes me
Posted: 03/04/08 05:27pm Link  |  Quote  |  Print  |  Notify Moderator
If it is the propane model....??????? Gas model requires a change to the altitude switch.....that my cause a change in the mixture level...
Moomba2002
Sebastopol, CA
Posted: 03/04/08 09:09pm Link  |  Quote  |  Print  |  Notify Moderator
It is propane.
Katesback
Nashville, TN
Posted: 03/05/08 06:13am Link  |  Quote  |  Print  |  Notify Moderator
Being a technician I have experienced this sort of thing all to often. For the most part it is gas models with gumed up carbs. I would say the first thing is to get in there with an air hose and blow the entire unit out. Animals love building nests in generators and these can cause problems. If that does not solve your problem there are just two other areas that are prime suspect and fuel control is the most likely. the other is the computer board but not likely as you discribe. I would guess you have******and oil and god knows what obstructing the fuel passages in the delivery system.
Katie
skipbee
Glen Arm,Md. 21057 USA
Posted: 03/05/08 07:32am Link  |  Quote  |  Print  |  Notify Moderator
There is a small rubber tube that protrudes from the bottom,outside of the genset. Often bugs build webs in it. After cleaning with a flexible wire, I made a screen filter.It is a common problem with this unit. I'd try this first.
skipbee
2004 F350 Diesel CC SRW 19.5" Rikson W/T 4WD
2005 Lance 1121 with a little less of everything
12' Porta-Bote alongside
All that glitters is not gold. All who wander are not lost. Wm. Shakespeare
