RV.Net Open Roads Forum: Fifth-Wheels: In bed trailer receptacle
 > In bed trailer receptacle
jliveit
ohio
Posted: 03/06/08 06:21pm Link  |  Quote  |  Print  |  Notify Moderator
Where do you mount the receptacle in the bed of your pickup, everything I find that has the Y connector that allows me to keep my bumper receptacle comes with like a 7' cord and the receptacle looks very large (long). I was in hopes of mounting it in the driver side rear corner of the bed. Like recessed into a panel opposed to just mounting a bracket to the bed rail.
lewiselreno
El Reno, OK
Posted: 03/06/08 06:29pm Link  |  Quote  |  Print  |  Notify Moderator
I mounted mine in the bed, drivers side, about two to three inches from the tailgate. I cut a hole and flush mounted it to the inside out of the way. If you like, I can get a picture and post to show you where it is.
Steven
2006 Cypress 34BLSK Triple slide
1200 watt inverter
5500 watt generator
2006 Ford F-250 Lariat 4x4 6.0 Diesel
Workhorse performance chip
Magellan GPS
Extra 100# propane cylinder
JJnLilly
Ohio
Posted: 03/06/08 06:34pm Link  |  Quote  |  Print  |  Notify Moderator
Mine is installed in the bed - flush on the left rear about 10" forward of the tailgate. Could have used the one on the bumper hitch, but wanted to avoid the rubbing of the cable over the bed. My vehicle had a connection in the harness that required only a plug in connector. No wire cutting or splicing. Another Buckeye here.....
2007 Ram 2500 QC CTD
2004 Cougar 290RK
hyattjlbb
Minot, ND
Posted: 03/06/08 06:39pm Link  |  Quote  |  Print  |  Notify Moderator
I have mine on the drivers side in front of the wheel well behind the cab. Unfortunately that is the way it was when I bought the truck and don't want to cut another hole in the bed. Had I done it from the beginning I would have mounted it back by the tailgate as I have to reach over the bed rail to access and it drives me nuts!
2007 Jayco Jay-Flight 31.5BHDS
2006 Chevy Silverado CC/SB 2500HD, Duramax/Allison
Beautiful Wife of only 12 Years
Boy - 10yrs
Boy - 4yrs
Greentow
Dover, DE 19904
Posted: 03/06/08 06:46pm Link  |  Quote  |  Print  |  Notify Moderator
Left side, about a foot forward of the tailgate. Works for me. And I still have the bumper mounted AND a 4-pin next to that.
Lee
2004.5 Dodge 3500 DRW QC, 4x4 LB, CTD 600 ,auto,4.10 , Prodigy, 05 Cedar Creek 36 RLTS w/ lots of bells & whistles .Honda 3000 genset. Mrs Greentow & Missy, Shih Tzu with an attitude. USA(R). 30+ years in the Fire/EMS service. CCRVC #29, GS Life member
jliveit
ohio
Posted: 03/06/08 06:52pm Link  |  Quote  |  Print  |  Notify Moderator
Yes, picture would be nice since I can't seem to picture where in the bed you can drill the hole with enough depth to mount the receptacle and hide the wires.
Dave H M
IL
Posted: 03/06/08 07:08pm Link  |  Quote  |  Print  |  Notify Moderator
get comfy on the ground and look up under the bed sheet metal just in front of the fender well, plenty of room on my F 250.
Sure I have to reach over the bed rail but I don't have to snake in between the trailer and the bed for the mount in front of the tail gate. little practice and you can do it by feel
XRing
West Chester Ohio
Posted: 03/06/08 07:49pm Link  |  Quote  |  Print  |  Notify Moderator
Drivers side, just inside the tailgate.
2004 Chev. 2500HD 4x4
crew cab 8100/Allison
2005 Jayco Eagle 305BHS
If you can read this thank a teacher, if you can read it in English, thank a Vet.
Semper Fidelis
Mike_5667
Southern Ohio
Posted: 03/06/08 08:08pm Link  |  Quote  |  Print  |  Notify Moderator
Hi jliveit,
I have a 2004 3/4 ton Silverado with an 8' bed. I installed a second 7 pin receptacle inside the bed on the driver's side just inside the tail gate. There was plenty of room behind the sheet metal where I drilled. After cutting the 1½”(?) hole I could easily reach from underneath the truck and feed the wiring to the hole. See the picture.
Good luck,
Mike
robbins
Sonora, Ca
Posted: 03/06/08 08:46pm Link  |  Quote  |  Print  |  Notify Moderator
Mine is mounted just ahead of the driver side wheel well. Lots of room there on my 2500. I have permanent mounted behind wheel tool boxes.
See 'ya on top
Keith
2004 2500HD silverado 4x2 extra-cab
265/75/16 Hercules tires
Reese 15000 Pro Hitch
2006 Gulf Stream 30FBRG
