RV.Net Open Roads Forum: Class A Motorhomes: WATER LEAK IN 2004 DUTCH STAR
 > WATER LEAK IN 2004 DUTCH STAR
USMC46
Richmond, Tx.
Posted: 03/07/08 01:25am Link  |  Quote  |  Print  |  Notify Moderator
Am parked on Padre Island. Noticed a water leak . Water is leaking down inside the basement directly beneath the kitchen sink. Also have some water on cabin floor running along the front of the cabinet baseboard. No water directly under the sink. No leak at the drain traps. However the leak starts when water is run through the kitchen sink faucet. Quit using the faucet and no leak.
It unit is a 41' 2004 Dutch Star Model 4025.
Any ideas ?
Jim & Carmel
2004 Dutch Star 41'
2006 Jeep Liberty
Blue Ox Aventa Tow Bar
Brake Buddy
wamesit
lowell ma. usa
Posted: 03/07/08 02:09am Link  |  Quote  |  Print  |  Notify Moderator
I think you self diagnosed the problem. Check the cold line under the sink, check the connections at the faucet. If not their, check the line back to the city water connection. Also if its on a slide check the fittings. Good Luck Chuck.
Donna and Chuck
2004 Dutchstar Model 4009 tripple slide
Spartan chasis and 370 ISL Cummins
2003 Saturn L-300 (toad)
1998 Hi-Line Park Model trailor up in Maine
2 chihuahua one female (chi-chi) one male (Alabama)
Aridon
SE Florida
Posted: 03/07/08 02:25am Link  |  Quote  |  Print  |  Notify Moderator
Aye, check all the connections under the sink. They tend to rattle loose over time if not tightened every so often. Good luck finding it.
2008 Newmar 4330 (Modified)
gunny357
North Carolina
Posted: 03/07/08 03:52am Link  |  Quote  |  Print  |  Notify Moderator
Is there a slide involved?
B's Bunch
Shelbyville, TN. USA Why live any where else?
Posted: 03/07/08 05:15am Link  |  Quote  |  Print  |  Notify Moderator
Ours has a finger thin water filter mounted on the side of the cabinets. If you did not know it was there you would not see it. There are fittings to by pass this. Ours has come loose and leaked before. As others have said tighten all fittings be carful not to over tighten Larry
Larry,Brenda,Travis,Jarred & MEME the Boston Terrier The BUNCH 05 Dutch Star 4024 Antelope.Toad 08 Jeep Rubicon Unlimited Four Door Rescue Green Love It!US Gear brakes 06 Ultra Classic Man What a Ride If at first you don't succeed don't try sky diving
st687
tampa Fl
Posted: 03/07/08 05:18am Link  |  Quote  |  Print  |  Notify Moderator
Do you have a pull out faucet, if so check the hose, thats where my leak was.
Doris &Bill
97 U270 Foretravel
05 Saturn Vue 265HP
When all else fails call a MARINE
Semper Fi.
Bumpyroad
Virginia
Posted: 03/07/08 05:32am Link  |  Quote  |  Print  |  Notify Moderator
obviously, leak must be "after" the shutoff point for that tap. that limits, but confuses the situation IMHO.
bumpy
marvmarcy
Polson, MT, USA
Posted: 03/07/08 07:10am Link  |  Quote  |  Print  |  Notify Moderator
My water pump is beneath the cabinet under the sink. I have a fitting on one of the lines by the pump that leaks when pressure goes up to around 80-90 lbs. It wets the floor under the cabinet and along the floor outside the cabinet. I have added a very good whole house regulator to keep the pressure at 40 lbs, and that stopped the leaking completely.
Although your water pump may not be under the sink, there are lines running below the cabinet to supply the sink. One of them is likely leaking, probably one of the fitting clamps.
JMHO
Marv
2001 Volvo VNL42T420, ISX450/1650, super 10sp w/GearMaster
2003 Newmar Mountain Aire 38RLRK
Piaggio MP3 400 scooter
RVing since 1979 - Fulltime since 2000 (mostly CO, MT, NC & Key West)
Retired USAF
Bumpyroad
Virginia
Posted: 03/07/08 09:05am Link  |  Quote  |  Print  |  Notify Moderator
good grief, I didn't know that the systems would hold up to 80-90 lbs.
you certainly needed a pressure regulator.
bumpy
bingoldsby
Oregon State Parks - somewhere
Posted: 03/07/08 09:27am Link  |  Quote  |  Print  |  Notify Moderator
Jim,
HOW did you "stop using the fawcet?" Did you just stop turning it on at the sink or did you find a water shut-off valve back inside somewhere and kill it there?
If the former, and as you have described the situation, it seems likely that the fawcet mechanism isself is leaking somewhere when the valve is turned to on.
You might tell us what kind of fixture the fawcet is - ie. single lever type or two-descrete-knob type and what the spout looks like.
What makes me ask, is that you say it only leaks when running water. That would eliminate leaks in the lines all the way up to the sink tap.
Brian K7ZRZ
Campgrounding hosting - Oregon State Parks
1987 30' Holiday Rambler Class A
GL1800 Goldwing - Honda Scooter Mounted
2000 Silver Miata LS Toad
Picture taken at Salem, Oregon
