RV.Net Open Roads Forum: Toy Haulers: Raptor Fuel Station Problem
Search only in Toy Haulers
 > Raptor Fuel Station Problem
wild bill
Mira Loma, Ca. USA
Posted: 03/07/08 07:57pm Link  |  Quote  |  Print  |  Notify Moderator
Tried to get a little gas from the fuel station tonight and when I turned on the switch heard a click as I moved from on to off and the motor did not start? Always worked fine before....Sounds like the pump is stuck? Anyone had theirs apart? Any suggestions. Thanks Bill
05 Dodge 3500 Q-Cab,GearVendor 8 Sp,PacBrake,Banks intercooler & intake,TST R49,Transferflow 70 tank,TrailerSaver Hitch,05 Raptor 3612,Second AC, solar 6 battery sys Xantrex 3000,Sand Rail 02 Nightrain,ST4s KLR650,ll00RT,AOPA BMWMOA,EAA,HOG,TDR,NRA,FCSA
coribdx
on the road
Posted: 03/07/08 08:35pm Link  |  Quote  |  Print  |  Notify Moderator
Ours did not work on the first trip out.. something to do with a gear in the pump motor that swells... ask your dealership about it. They fixed ours while we waited..
RCFlyer
Washougal, WA, USA
Posted: 03/07/08 11:19pm Link  |  Quote  |  Print  |  Notify Moderator
It's a pretty common problem on '05/'06 Raptors, and a fairly quick fix, but it does require a couple new parts. As coribdx says has to do with the pump gears not meshing properly which overloads the motor and causes shut down. I think they put gears and a shim in ours.
By the way, nice flames on the TV!
2005 F-350 SRW LB Black Harley Davdsn, 6.0 Pstroke w/auto, Excite liner, ARE "Z" cap w/Yakima rails & slide/tilt window, PIAA 1500 bu lights. B&W TO Ball hitch, Firestone bags
Wife: Stef the quilter
Dog: Chase, the Golden Retriever
3 sons, 8 grandkids
Y-Guy
Tri-Cities, WA
Posted: 03/07/08 11:34pm Link  |  Quote  |  Print  |  Notify Moderator
wild bill - this was pretty common a year or two ago, if you use the advanced search and go back over 12 months ago you may find some older posts about this too.
Forced Family Fun... They'll thank you later for it!
Have you checked out the new RV.net Blogs?
jchappy
Imperial, Ca
Posted: 03/10/08 09:40pm Link  |  Quote  |  Print  |  Notify Moderator
Wild bill
As some have said it is due to the gears swelling. I did this fix to my raptor in a few hours. Take your pump out and take off the back plate where the gears are and grind down the side of the gears on a belt sander(only for a second)on both sides. the issue is when they swell the cover kept it from turning so grinding it just a hair frees it up. My trailer is still under warr. but it was going to be a 4 week wait just to do a 2 hour job.
2005 Chevy Silverado 2500HD Duramax/Allison 4X4
2005 Raptor Toyhauler 3018TT
Building a V3SS Sandcars.net
