KenS999
Elgin,IL
Hello,
In am in need of 6 replacement tires for a recently purchased used 24' class C built on a Ford E350. Tire size LT225/75/R16. I am looking at "E" load range tires. Can you please weigh in on 3 selections I have found and am considering. Uniroyal Liberator A/T, Goodyear Tracker 2, both sold through Walmart. The last is the Firestone Transforce HT. I want to be safety conscious while staying within a reasonable budget. I am very much a rookie here so any experience or recommendations you might share would indeed be helpful to me.
Thank you.
Ken
Elgin,IL
bsinmich
Holland, MI
I wwould check out Kelly & Cooper tires at a local tire store. My experience has been that WalMart has high prices on cheap tires. I had Kelly on a previous MH and they were great. I never had Cooper on any RVs but did have great experience with them on cars. I had good luck at Discount Tire and you have one in Elgin plus a few in the area.
2003 Newmar Mountain Aire, Workhorse W22, & 2002 PT Cruiser w/Remco lube pump, Falcon 5250, & US Gear Unified Tow Brake
RodT82721
Pine Haven, Wyoming
I replaced with the Firestone Transforce HT Load E last year. They were priced right and replaced Firestones. I am very happy with them. It seems most on here suggest Michelins. Whatever you decide make sure you have them put on solid valve stems that allow easy access to check/add air pressure on all the tires. I will never understand why they make checking & adding air so hard.
2001 Winnebago Minni - 31C
Ford E450 - V10 Triton
Tow - 2005 Jeep Liberty
Puckman
S.Cal/Mass.
Michelin XPS Ribs. You will not be disappointed
Puckman
S.Cal/Mass.
Second the suggestion on the solid valve stems. Also use the metal caps on the valve stems.
ron.dittmer
Near Chicago
Ken, I sent you a Private Message through this forum.
Bought new in June 2007, Phoenix Cruiser-2350
Fits inside our garage.
Dingy towing a red Toyota MR2 Spyder
See The Inside by clicking on "View Profile" and scroll down
Dakzuki
Carnation, Wa, USA
Like the others said. If you have rubber valve stems, get rid of them. There are a number of options once that is done but I think the consensus here would be to lose the rubber ones when you change tires. My brother had a rubber one fail on his rig so that is enough data for me.
I'm not going to get into a tire preference discussion (a bit like religion and politics) but suffice to say Discount Tire was matching Costco's price on Michelins when I bought tires last summer. They also gave me Es rather than Ds at the same price which didn't bother me at all AND I got to not deal with the Costco Chaos. I made an appointment, dropped the rig off in the morning and picked her up a bit later.
95 Chinook Premier
revdsid
Kalamazoo
The Coopers wont last. The B.F. Goodrich Commercial A/T is better than the Cooper but not as good as the Michelin. The XPS is for a 30/31 footer where every pound matters. Absolutely no rubber valves or woven extensions. Buy the solid extended valves. I can change an inside dually in my sleep-- the one skill I would prefer not being expert at.
buchrob
Stanstead QC
I researched several specific tires I will need during the next 3 months, and Wally was the MOST expensive.
I can't see spending the few extra bucks for the pleasure of dealing with their uniquely qualified staff.
Discount Tire (with their price guarantee), here I come.
'99 Glendale Royal Expedition 24' Class C
2003 Subaru WRX wagon as toad.
wip
Manhattan Kansas
My mechanic warned me against putting goodyear tires on large vehicles. He said that they are prone to cupping, and that they therefore need to be rotated more frequently.
crc
