RV.Net Open Roads Forum: Towing: Weight distribution question
Search only in Towing
Open Roads Forum  >  Towing
 > Weight distribution question
00zx6r
Ca
Posted: 03/09/08 08:28am Link  |  Quote  |  Print  |  Notify Moderator
Does anyone know how much weight percentage the weight distribution transfer to TV's rear axle?
2001 E450 Fourwinds Majestic 26
2004 Dodge Durango Limited Hemi 4x4 LO
2005 18' Haulmark enclosed trailer
2005 Honda CBR1000RR Resol
2004 Honda CBR1000RR Silver
2002 Honda CR250
2005 Honda 250 Recon ES
2002 Honda TRX90
2000 Kawasaki KX 250
TXiceman
(Near) Houston,TX
Posted: 03/09/08 08:56am Link  |  Quote  |  Print  |  Notify Moderator
Really depends on the trailer, the truck and how the hitch is set up. The only way to know is to weight the truck and trailer separately and then again hooked up.
Some of the weight is also transfered to the trucks front axle as well as the trailer axles.
Ken
KE5DFR
Vintage 1979 Silver Streak Supreme Rocket toted by a 2002 F350, crewcab dually, 7.3L,4.10 axle,SCMT. Travel with two miniature Schnauzers and one African Gray parrot. Practicing for retirement!
kirk37r
Millville, New Jersey
Posted: 03/09/08 08:57am Link  |  Quote  |  Print  |  Notify Moderator
Take A look at the sticky on top of this page it has a lot of good info for you, Ideally WD should transfer 1/3 to TT axles, TV rear axle and TV front end, But we don't live in An ideal world. You will get A lot of replies on your post.
Happy Camping!!!!
2007 Wilderness Yukon 300RLS TT
2007 Silverado 1500 5.3 4X4 Extended Cab, Z71 & Z85
2008 Tahoe LS
Reese WDH W/Dual Cam, Prodigy Brake controller
Putnam XDR
Carol & Kirk Sometimes 3 Grandkids
TURK2500
S.E., Michigan
Posted: 03/09/08 10:01am Link  |  Quote  |  Print  |  Notify Moderator
A properly sized WD hitch when engaged will remove weight from the TV's rear axle, thus distributing the weight to the TV's front axle and to the TT axles.
As mentioned, not all TV/TT's combinations are created equal (suspensions, loading habits, etc.), so a weigh-in at your local CAT scale will give you "actual" axle weight conditions with your WD spring bars engaged.
You may find this link of interest.
Turk2500
05 Jayco Eagle, 278FBS, UVW 7,063lbs, GVWR 9,000lbs.
Tongue Weight: Dry 913lbs/Loaded 1,200lbs.
02 Chevy, 2500HD/4x4, 6.0L/4:10, EC/LS/SB, Prodigy, GCWR 16,000lbs.
TV/TT loaded: 14,700lbs.
Putnam XDR Class V, Reese HP Dual Cam.
00 HD Road King Classic.
Pete D
Washington
Posted: 03/09/08 03:28pm Link  |  Quote  |  Print  |  Notify Moderator
It's a see-saw thing; the proportion of weight transferred to front axle and trailer axle will be dependent on the distance of each from the center of the hitch.
A short trailer on a tow vehicle with a long wheelbase will likely have a greater proportion of the weight on its axle(s) than the opposite.
1998 Ranger 4.0 4x4
1991 Scamp 13'
Terryallan
NC
Posted: 03/09/08 04:42pm Link  |  Quote  |  Print  |  Notify Moderator
If you have a owner's manuel for your TV. The setup instructions are in there. For my Ford. The manuel says to adjust the WDH by measuring the front and rear un hooked. The when you hook up. The front should settle with in 1/4 inch of the rear, with the rear being no "higher" than it was unhooked.
In othere words. If your TV rear settles 1 inch. The front should settle 3/4 inch. Mine settles 1/2 inch in back, and 1/4 inch in front. Tows great. No sway at all. Also if you have an air ride leveling system on the TV. Turn it off to adjust the hitch.
This is the most simple way. And works perfectly, Plus you can do it in the nearest flat spot.
Terry & Shay
Pioneer 23T6
04 F150, 5.4, Lariat SuperCab
Lazy Campers
NC
Chuck&Gail
In the Colorado Mountains
Posted: 03/09/08 04:52pm Link  |  Quote  |  Print  |  Notify Moderator
My TV also settles about 1/4" more in rear than in front when properly hooked up.
Note you want TT tongue weight to be about 13% of FULLY LOADED TT weight BEFORE you set up your WD hitch.
Chuck
Wonderful Wife
Lovely German Shepherd.
1999 Mercedes ML320 TV
2003 Wanderer 187TB Toybox (3620# UVW, 4800# loaded)
Not yet camped in Hawaii, 2 Canada Provinces, & 2 Territories.
00zx6r
Ca
Posted: 03/10/08 11:31am Link  |  Quote  |  Print  |  Notify Moderator
Thanks everyone for the nice reply and info. I am currently towing tandem axle enclosed trailer 18' with 860 lbs TW and 5800 lbs trailer loaded with my class C and 04 Dodge Durango.
I am towing without WD and thinking to buy a Eaz-lift 10k WD and want to see how much tongue weight will be transfer to the front axle of the class C and the Durango.
Thanks again everyone and Happy Camping !
Caddywhompus
Southeast WI
Posted: 03/10/08 12:03pm Link  |  Quote  |  Print  |  Notify Moderator
Your two different tow vehicles are going to result in completely different weight distributions.
The Durango will easily be set up to transfer a significant amount of weight to the front axle, and very little will end up on the trailer axles. The Class C is going to do the opposite. It will remove weight from the rear axle of the vehicle, but most of that weight will end up back onto the trailer's axles, very little will move forward to the front axle.
In either case, you are much better off with WD than without. In fact, you are likely WELL over your receiver's tongue weight rating at 860 pounds if you aren't using WD already. Most class III receivers have a weight carrying limit of 500-750 pounds, and require the WD hitch to handle more than that.
-Jimmy
'04 Ford Freestar (Primary tow vehicle)
'05 Subaru Forester (Backup tow vehicle)
'65 Bethany popup (best popups ever made!)
Looking for a tow vehicle
Minivan towing
mkirsch
Rochester, NY
Posted: 03/10/08 12:08pm Link  |  Quote  |  Print  |  Notify Moderator
Also be sure your Class C is compatible with a WD hitch. Many/most class C manufacturers prohibit WD hitch use because the frame extensions are not built heavy enough to withstand the "pry up" forces from the WD hitch.
