turbopilot51
Ridgefield, WA
While de-winterizing the rv today, I noticed a small leak from the outside shower. The leak is coming from the cold water knob around the valve stem. I don't see any way to tighten around the the stem. Any suggestions?
downtheroad
Puget Sound
Outside shower are notorious for leaking after winter... freeze damage - did you remember to fully winterize it last fall? The entire unit is easily obtained and replaced. Most any RV outlet will have the unit. They are not all that expensive.
GMC Duramax/Allison (LBZ)
Komfort 277TS Our Rig Pic
Reese Dual Cam HP
