I know I saw this picture on this site. I wanted to know how he mounted the tie downs on the walls. Did he use a stud finder to locate beams? What type of hardware did he use? And last but not least how sturdy has it been? If anyone else has any experience I would love to know how you did it.
edited 03/20/08 12:09am by an administrator/moderator *
2006 Ford F250, Power Stroke, Banks Exhaust, Air Lift Bags, Factory Tow Command, Mag-Hytec Diff cover, Toyo Tires, Fox Suspension and onboard air.
2007 Raptor 3612DS
2007 Yamaha WR 450
2005 Honda EX250
2005 Honda XR 70 ONE OF A KIND
I have an '08 Raptor and looked at some of Paul's pictures and have a similar setup with d-rings on the wall. I used a combination of stud finder and common sense. I followed the wall mounts of the metal shelf/table and found where the studs are. I also followed the mount points of the corner shelves and found where the studs were.
my benches were pulling out of the wall, I used toggle bolts to re-secure them. working well so far... If i mount anything else, i'll use either toggle bolts or hollow wall anchors and make sure and go into a "stud".
Marcus
Apple Valley, CA
2005 Tahoe Transport 27 FW WTB
2003 Chevy 1500HD
Many of the trailer supply houses have something similar to e track but made for bungee cords that is meant to fasten the whole length of your walls....It attaches with lots of small screws.... and has slots large enough to get a bungee hook into every couple of inches the entire length of the wall....I have used this system for over three years now and have not had any problems....
I've got factory PDF's of the wall stud layout/floors for the 2006 3712TS. I think the garage areas in the 3712 and the 3612 are framed the same, but not sure how the newer models compare.
If these drawings will help anybody send me a PM with your REGULAR EMAIL address and I'll be happy to forward - files are too large to post here.
2005 F-350 SRW LB Black Harley Davdsn, 6.0 Pstroke w/auto, Excite liner, ARE "Z" cap w/Yakima rails & slide/tilt window, PIAA 1500 bu lights. B&W TO Ball hitch, Firestone bags
Wife: Stef the quilter
Dog: Chase, the Golden Retriever
3 sons, 8 grandkids
I used some Cobra panel door drillers (see photo) these were short enough not to push against the outside wall. Ideally look at your rig when its early in the morning and see if you can mark the dew lines then use those to pinpoint an aluminum stud.
Forced Family Fun... They'll thank you later for it! Have you checked out the new RV.net Blogs?
Y-Guy wrote: I used some Cobra panel door drillers (see photo) these were short enough not to push against the outside wall. Ideally look at your rig when its early in the morning and see if you can mark the dew lines then use those to pinpoint an aluminum stud.
Yguy, that's right!!! I forgot about the dew lines in the morning. Smart thinkin'!
2004 30' Fleetwood Gearbox FS, RevRed
2003 Ford F250,6.0L,4x4,CrewCab,4.5"D.R.Lift, 35"BFG's
2002 Honda CRF450
2004 Honda CRF230
2007 Kawasaki KX85
2004 Honda CRF70
2000 Honda Shadow Sabre 1100
and a couple of Jet Skis
