RV.Net Open Roads Forum: Fifth-Wheels: Too much for my truck?
 > Too much for my truck?
awmasparky
Murrieta, CA, USA
Posted: 03/18/08 08:15am Link  |  Quote  |  Print  |  Notify Moderator
Ok here it goes. I have a 1996 Ford F250 fwd with a 460 and 4.11 differential. Towing capacity max is 12k. I want to tow my 5th wheel which is 36' and around 11K on one trip to my place in Montana. The trip is about 1300 miles. I still need to check on gvw issues. My question is, does anyone have a similar set up? I'm sure that there are many opinions on this. As I've stated I still need to check all the weight issues.
99 Dodge Ram 2500 2WD CTD,Banks power pack plus, exhaust brake. 2006 Six Pac D850.
donn0128
Pronounced Ore-gun
Posted: 03/18/08 08:22am Link  |  Quote  |  Print  |  Notify Moderator
One trip? Make sure the trailer is empty, tires and brakes in good shape and tow it up there!
Donn
skipnchar
Topeka Kansas USA
Posted: 03/18/08 09:13am Link  |  Quote  |  Print  |  Notify Moderator
I DOUBT if you're concerned about warranty on your truck so the numbers you need to be concerned about are the trucks GVWR and the rear axle GAWR. Good luck / Skip
Capt Skup
Southern Maryland/Nantucket
Posted: 03/18/08 09:31am Link  |  Quote  |  Print  |  Notify Moderator
Make sure your trucks tires and brakes are in good working order, tires Load Range "E" pumped up to 80PSI, trailer tires and brakes in good working order, pumped up to proper setting(don't forget your spares), lightly load the trailer, leave water tanks empty, stay at the speed limit and you will have a fun trip. I carried 6-8 500lb weight boxes for elevator testing in that year F-350 SRW 4x4 trucks many many times and the trucks held up well, the 460 is a guzzler but a great towing engine
Capt Skup
AD-1(AW)USN Ret.
Wonderful Wife, 3 beautiful Daughters
"Never get in a battle of wits with an unarmed man"
2008 F-450 Lariat 4x4
2008 Honda Odyssey EX-L
SunlineF281SR
SeaRay215EC
http://community.webshots.com/user/CaptSkup?vhost=community
mexfishguide
arkansas
Posted: 03/18/08 01:38pm Link  |  Quote  |  Print  |  Notify Moderator
I have used several 460ci ford enginees to pull 5th wheels, my last one pulled a 35' 5th with slide out, coast to coast no trouble. it is a good enginee just stand on it and don't miss a gas station.
Take Care
Mexfishguide
awmasparky
Murrieta, CA, USA
Posted: 03/19/08 04:16pm Link  |  Quote  |  Print  |  Notify Moderator
Thanks for the replies.
I forgot to ask about mpg. I am hoping for at least 5 mpg, is that a reasonable expectation?
rconkin
Johnson City, TN
Posted: 03/19/08 06:07pm Link  |  Quote  |  Print  |  Notify Moderator
Just curious, why are you not using the CTD in your sig? Is it because it is 2wd?
97 2500 CTD, US Gear Exhaust Brake, Prime-Loc, Silencer Ring removed
02 Jayco Eagle 305BHS
"For those that fought for it, Freedom has a flavor that the protected will never know!" Semper Fi
irydasteelhorse
billings mt
Posted: 03/19/08 06:43pm Link  |  Quote  |  Print  |  Notify Moderator
i have the same truck, 95 ford f250 4x with the 460/5 spd. you will have NO trouble at all with that trailer. stay at 60 mph or so....i get 9 1/2 to 10 mpg, at around 62. i also have NO trouble with mountains....and here in montana, we have MOUNTAINS! the faster you go, the lower the mileage. like others said above, please make sure your tires and brakes are up to it.
awmasparky
Murrieta, CA, USA
Posted: 03/20/08 08:37am Link  |  Quote  |  Print  |  Notify Moderator
rconkin
The Dodge has a few problems. It was also suppose to be sold. However I may end up fixing it and using it. The ford was purchased to be left in Montana for use when we come up. The Dodge has the gooseneck hitch installed and nice towing mirrors and when it is running correctly it tows great.
I figure I will need to invest another 2k to get it running again. I am going to have the Banks system remove and maybe a chip installed. The Banks system is great when it is working. But because of the problems I have had, I would never do it again. I spent around $3500.00 for the system and it worked for a few months and had to have the electronics replaced. Then not 6 months later it quit working. When I finally took it in again I was told that the electronics are obsolete and can't be replaced. They replace the wiring harness plug and it lasted another 6 or 7 months. So I am tired of messing with the Banks system.
Road Phantom
pa
Posted: 03/20/08 09:12am Link  |  Quote  |  Print  |  Notify Moderator
11 k sounds a little light for a 36 ft'er. Have it weighed. I suspect that it might come in around 12-13. Unless it doesn't have any slides.
