RV.Net Open Roads Forum: Truck Campers: Torklift vs Happijack tiedown systems
 > Torklift vs Happijack tiedown systems
spkncarl
Southwest Desert
Posted: 03/20/08 09:21am Link  |  Quote  |  Print  |  Notify Moderator
Sorry I can't say I've used both....I chose TL and FastGuns when I set up the TC. I've been very pleased.
WarrenS
Cypress, CA, USA
Posted: 03/20/08 09:40am Link  |  Quote  |  Print  |  Notify Moderator
I had the HappiJack system and a Reese Tow Beast (bed and bumper mounts and QuickLoads). I was over the rating for the Tow Beast extension. I switched to TorkLift (front and rear frame mounts, SuperHitch, and FastGuns). No other changes were made to my setup at that time. What I noticed:
  • Camper rides more stable.
  • FastGuns are much easier to adjust than traditional turnbuckles, QuickLoads, or Derringers.
  • I tend to offload the camper much more readily.
  • Truck looks better without the bed mounted tie downs when the truck is off.::The brackets that tie the HappiJack system to the frame of the truck are not very substantial. I'm much happier with a direct to the frame system.
I know the TorkLift system is more expensive but it's worth it for a heavy camper. If you're looking at a very lightweight camper the HappiJack tie downs are fine though I'd still recommend a set of FastGun turnbuckles (Torklift makes a short version for use with HappiJack tie downs) if you intend to offload regularly or use the jacks to level the camper.
Happy Trails,
- Warren
Wife, 6 year old boy, 4 year old girl
01 Lance 961 (9'6 with slide out). TorkLift Frame Moutned tie downs, FastGuns, SuperHitch
05 Chevy DRW,LB,CC,4x4,8.1L gas, Alison
78 Toyota FJ40 w/'97 350 Chevy & auto. trans.
87 Honda TRX250R
WA1RI
FL
Posted: 03/20/08 09:46am Link  |  Quote  |  Print  |  Notify Moderator
Had both. HJ worked fine on my old truck, but when I bought the new truck I switched. Much easier to use, (I had the HJ turnbuckle system), (Now have the fast guns), the cust service is great.
Bill & Jolene / FL
1997 Southwind 35P
2006 Yamaha 1100 Classic &
1970 Norton Commando 750 in state of recuperation (Almost road ready!!!)
6x12 Enclosd trailer
FF1063
LI, NY
Posted: 03/20/08 10:30am Link  |  Quote  |  Print  |  Notify Moderator
* This post was edited 08/04/08 07:05pm by FF1063 *
stevenal
Newport, OR, USA
Posted: 03/20/08 11:23am Link  |  Quote  |  Print  |  Notify Moderator
FF1063 wrote:
I've see this often, but if the camper is sitting in the same pickup bed, and you are using the same spring-loaded turnbuckles, why would it be more stable ?
'Cause bumpers are springier than spring loads on a solid trailer hitch mounted extension. And spring loads return while bumpers stay bent.
'99 Bigfoot 1500
with low loss control on the Fantastic, Dino board on the Dometic.
Torklifts and Fastguns
'04 F350 V10 Crew SRW SB 4X4 6 speed
with tow hook replacement, dual rate charging, Line-X, Timbrens.
Quincy Dually
Quincy, ca
Posted: 03/20/08 11:49am Link  |  Quote  |  Print  |  Notify Moderator
I have TL's on the front and HJ's on the back. The main reason I did that was because I am cheap, I had the HJ's when I got the bigger truck. I reinforced the rear bumper with a 1/4" thick piece of steel that bolts to the bumper bracket. This works fine and saved me a couple hundred dollars.
Jeff
'03 Ram 3500 DRW CTD,'02 Arctic Fox 990,'04 Tracker Super Guide 16'WT
Ribaco
Lakeville, ohio
Posted: 03/20/08 01:40pm Link  |  Quote  |  Print  |  Notify Moderator
I purchased the tork-lift system for our truck and have traveled many miles with no problems. I am pleased with engineering of system, very simple and fast. My only complaint is with the stainless steel which starts to show corrossion quickly although it can be removed with polish and waxing.
BradW
Flat Rock, Alabama
Posted: 03/20/08 03:25pm Link  |  Quote  |  Print  |  Notify Moderator
Either systems works great. They both have advantages and disadvantages. Pick the one you like.
Brad
Caution: Possibel defective spelling above; spell checker is DOA.
Our Truck Camper Photos
1996 Lance 500 and 2006 F-350 PSD 4X4 DRW
Visit the RV.net Blogs
jmtandem
carson city nv
Posted: 03/20/08 05:04pm Link  |  Quote  |  Print  |  Notify Moderator
Had both, prefer TorkLift.
'05 Dodge Cummins 4x4 dually 3500 white quadcab auto long bed airbags overload springs bumpers
'00 Elkhorn 10V w/basement
Grodyman
Posted: 03/20/08 06:10pm Link  |  Quote  |  Print  |  Notify Moderator
I have Torklift, but next time I will use Happijack. With Torklift, you have to install/remove sleeves to use, and then have to store them somewhere when off the truck. With happijacks, only have to remove and store turnbuckles. Much quicker and easier, not to mention cheaper.
2006 Dodge 2500/CTD/Quad/2WD LWB, Vision/245/19.5, Ride-Rite, Hellwig Overloads, Torklift/Superhitch, Fastguns, Line X. 2007 AF990 WetBath.
