5bythesea
Cape Cod
Hey Folks,
Probably a real foolish question, I removed the battery from our 06 Travel Trailer for the winter. Just went to go put it back in and now scratching my head. Black and White cables. Normally black is negative but I believe it can also be positive and white can be negative. How can I be sure?
Thanks in advance....
Tony
The Pop-UpMercman
Lee MA
BLACK is the positive, WHITE is Negative, like household wiring.
Your positive cable should have a inline fuse in it, that would be another way to tell.
FYI- I was confused at first also, so I wrote Black next to positive teminal on battery so I would remember.
Happy to be the wondering wanderer,
...As long as there sand in my toes.
01 F-150
07 Rockwood Freedom 1980
Official Vehicle of the Camping Collies
planter8
Utica, MI
The way my dad taught me about residential electrical: black is hot... BLACK, LIKE DEATH!
Planter8
Sunset Trail ST30BH
Ford Econoline E-150 wagon 5.4L V8 3.55 axle
Equal-I-zer hitch
smkettner
5bythesea wrote: How can I be sure?
Positive has the fuse/circuit breaker. Negative goes to the frame.
5bythesea
Cape Cod
Thanks everyone. I would have screwed it up. Lol
Big_Johnson
Columbus, Nebraska
If you would have hooked it up backwards it would have run your lights backwards, fans in reverse, your microwave in reverse and un-cook your food... It would be chaos putting your slides in and out... LOL, just kidding...
Yes Black is + (positive) white is - (ground)...
May be to hard to see...
Regards,
Rob
Website: www.robjohnson.info
2008 Sprinter 311BHS
2004 2500HD 4x4 C/C 6.6L Duramax/5-Allison
Putnam 16,000 lb.,Equal-i-zer 12,000LB./1,200LB.
Champion 3500W RV Generator
Got Diesel!
Got Wood!
Got Dark Beer!
Got GPS!
Need Warm Weather!!!
5bythesea
Cape Cod
Lol, I like that. Thanks a lot
sclark
Minnesota
If you are ever unsure, you can purchase a cheep voltmeter. Plug your RV in and test the output for polarity. Good luck!
2004.5 Dodge Cummins
2007 Wildcat 32QBBS
Pair of Honda 2000 Watt generators
