jrkowalski
Glendale, AZ
I am trying to find some heavy duty rubber coated padlocks for my new toy hauler ramp doors. The rubber cover looks like it will help to protect the finish on the door. Master Lock has smaller ones, but nothing bigger than 1 9/16" that I can find. http://www.masterlock.com/cgi-bin/style_search.pl?dir=/residential/homeyard/&style_id=A3&sub_style_id=C312
I have seen larger ones but can't seem to locate them on the internet.
Any help is appreciated.
JK
Moderator's Edit: Moved to Modifications & Accessories Category
edited 03/23/08 11:51am by an administrator/moderator *
fordsooperdootydieselsmoker
OrangeCountyCalifornia
HERE
You may consider instead a vinyl coated stainless steel aircraft cable and a good padlock. I think any padlocr, ruberized or not, is going to eventually rubb away some of the RV's filon finish. So check this out too...HERE2 because you can get it longer, to go thru both sides of the doors hasp,and loop around.
Kejsj30
Portland, Oregon
I used to use the vinyl coated padlocks that forsuperduty put up a link for. I now use the hocky puck type, found them to be more secure because it doesn't appear they can be cut with bolt cutters.
2008 Chevy Silverado 2500HD
2008 Keystone Raptor 3712TS
2000 Bayliner 2855 Sierra SunBridge Boat (SOLD)
2007 Raptor 700R
2007 YZF 450RSE
2008 Raptor 700RSE
BajaBerg7
Discovery Bay, Ca
I have been using the "hockey puck" for a few years, and it seems to work really well. No rub/ wear marks, weather resistant, and tamper-safe...
I got a three pack, keyed alike and use two on the ramp, and the third one to lock-up the toys.
F350 7.3L PSD SuperCrew
Vortex 365WTB 5ver
CRF 450X
AMA D36 XC #714E
MRANN #707P
ALBA Raptor 700
YFZ 350 (Banshee!!!)
LTZ 400
LTZ 50
My Pics
lightfoot
Cary, Illinois
I have been using the "hockey puck" for a few years also with no damage that I can see to the trailer. You will find a lot of them at the self storage places so they must be fairly secure.
2005 Rage'N SS2400
'94 Honda GL1500, 230,000+ mi.
2005 Chevy 2500HD ext cab, 8.1V8, Allison Trans and full trailer package
Y-Guy
Tri-Cities, WA
The other option, if it will fit is the Shackleless Round Solid Steel, nothing on it to cut. If you're clamp will work with it its about the best one out there. Should work with most setups like the one pictured earlier. Just needs the tabs like you see in the second picture here.
Forced Family Fun... They'll thank you later for it!
Have you checked out the new RV.net Blogs?
Kejsj30
Portland, Oregon
This is what I have on my trailer but, I was able to use the existing brackets on my trailer (I did have to file them down a bit to be able to get the cam on the lock to work but, they are slick).
My old trailer had too much gap for them to work though. When you pick them up just get two that are keyed alike (should be a code on the package).
BajaBerg7
Discovery Bay, Ca
I like these the best, but they wont work with our TH. Ive seen some that grind out the inside a little and make them work. The "pucks" are the next best thing.
nick250f
iowa
We use the puck style also.... Just remember to empty them out of water every so often.... I notice ours fill up sometimes...and also they will freeze shut...
jrkowalski
Glendale, AZ
Thanks for all the great feedback. The picture really helped alot. I will see if I can get one of the Shackless Round Steel locks to work and if not, go with one of the "hockey puck" syle locks.
I also received advice from someone else telling me about using the cable method, but just can't visualize how that would work and what the advantage would be.
Thanks to all for your feedback.
JK
