PROJEKT
Phoenix
Considering upgrading to 16" wheels so I can run some load range E's with 3000# capacity tires, but I'd rather go the less expensive route and upgrade my tires.
I can get 15" load range E, but I don't know if the WW rims are rated to 80psi.
Anyone know?
TIM
2006 Dodge Ram CTD and WW FSC2800
2007 Rhino with all the u$ual crap
2006 Predator 500, 90 and Sawtooth 200
JJ&kids
North Tustin, Ca
I don't know what wheel WW put on your trailer.
most steel wheels will not be rated for 80 psi
whatever wheels you use make sure you use truck valve stems
good luck
03 Chevy 2500HD Duramax/Allison Crew Cab Short Bed
08 Attitude T23AK
01 660 Raptor
02 Yamaha 350 Warrior
04 Honda 250EX
04 Suzuki Z400
Chuck&Gail
In the Colorado Mountains
I'll bet your wheels have a rating on them. Unfortunately you need to dismount the tire to see rating, which is normally in valley on rim UNDER the tire.
Even if one poster knows his, are you willing to bet your life yours are the same?
Just my opinion.
Chuck
Wonderful Wife
Lovely German Shepherd.
1999 Mercedes ML320 TV
2003 Wanderer 187TB Toybox (3620# UVW, 4800# loaded)
Not yet camped in Hawaii, 2 Canada Provinces, & 2 Territories.
high desert
Verdi, Nevada
The 15" wheels that came on my '06 WW were not rated to 80 psi.
06 Silverado 3500 CC DRW 4x4 LT3 D/A
06 Weekend Warrior FSC2800, billet
Putnam XDR/Hensley Arrow
BrakeSmart
08 Polaris Outlaw 525 KTM IRS
08 Honda TRX 400 EX
08 Polaris Scrambler 500 4x4
2 Honda Foreman 4x4
Honda TRX 250 EX
Honda TRX 90
PROJEKT
Phoenix
high desert wrote: The 15" wheels that came on my '06 WW were not rated to 80 psi.
We've got the same trailer, and I've got the same concerns you had.
I'd like to avoid spending the $1500, but it looks like I'm going to have to.
Thanks for your help.
TIM
jackxclan
bakersfield
Mine were rated at 80lbs's but only 2100lbs per wheel soo my new 16 in. wheels are eagle alloys rated at 3200lbs and 80 lbs's
My tire guy says all the chrome steel wheels are the same 2100 lbs's
Gun metal gray 07 new body style 3500 diesel crew cab 4x4 dually
red WW fsc 28 tiki hauler
red 400 ex
black 250ex
red 400ex
red 250ex
red KW heavy iron hauler
HOOLIGAN # 385
pcassidy111
California
I just put new Denman 225 75R15 load range E on my 05 WW FS2600. Installed the tires myself and there was no rating (psi or weight) anywhere on the wheel, only the size and date of manufacture. The wheels are made by Carlisle in Socal so I called them (909 947-1831), talked to Robin in customer service and asked if it was ok to run 80 psi and/or 70 psi. I waited while she talked to engineering and she came back to say 70 psi was ok but not 80 psi. FWIW my wheels came with steel valve stems.
Pete
quad1100
Northern, CA
Wow, I have had E rated tires on my WW for 3 years now. What is going to fail on the wheels if they are not rated for these tires?
2003 2500HD D/A
2004 40' SLC3905 Weekend Warrior
lincster
Mesa Az
The stock Warrior 15" wheels are rated to 65psi and that is all.
2006 F350 PSD CC 4X4 Dually w/Tow Boss package to pull 2006 LE3905
Lincsters Truck/Trailer
Lincsters Rail
JIMNLIN
Big Cabin, OK
a wheel that is carring over pressure rating will usually split around the bead seat flange after weight is added and usually lets go when making hard turns which puts side stresses on the wheel. any folks use etrailerpart.com for 16" trailer wheels. Great bunch to deal with.
Jim
'03 2500 Dodge/Cummins HO 3.73 6 speed manual Jacobs
'97 Park Avanue 28' with two slides
