wingsoversj
San Jose Ca. 95125
Does anyone know if a prius can be towed behind an rv as long as the front tires are off the ground. The owners manuel is not quite that informative. I know its front wheel drive and that front wheels cannot be on the ground while towing. but can it be towed with a tow dolly for long distances without damaging anything.
2003 Gulfstream Mako 28frbh
2003 Ford F350 4x4 6.0 psd 5spd torque shift 3.73
Deen
Vancouver, WA
wingsoversj wrote: Does anyone know if a prius can be towed behind an rv as long as the front tires are off the ground. The owners manuel is not quite that informative. I know its front wheel drive and that front wheels cannot be on the ground while towing. but can it be towed with a tow dolly for long distances without damaging anything. That's a good question (but should be in the Towed forum). I've been wondering if there is any regenerative circuity in the rear wheels or are they freewheeling?
Deen - Vancouver, WA
'02 Dutch Star 4090 (41+', triple slide)
435/1200 ISC Cummins/Banks PowerPak
'08 Honda Civic/dolly
'05 Honda Odyssey/dolly
NRA Benefactor Life Member
FMCA f47302s, Life Member: Good Sam,
Newmar DP Owners Group
51st yr of RV'ing
Leeblev
Pinole, CA
Short answer: yes, if the vehicle is on a tow dolly. The only concern the mfgr has is that the tranny is not made for towing 4 down. I tow a Honda Civic on a tow dolly and have logged many k miles and never had an issue with the car. The mfgr did have a warning that it was not towable, but just not towable 4 down.
By the way, I like my tow dollie because it tracks well and has electric brakes that do help, even though I have air brakes.
Lee
2001 36' Kountry Star DP
Goldencrazy
madison wi
I towed my 05 Prius on a dolly. Towed about 2600 miles this winter in ice and snow and some wind. It was without problem. Once when I unloaded it took about 1000 ft of rolling under power for my idiot lights to go off including the brake lights. I had read about this in another post so wasn't concerned but it was nice to know I didn't have a problem. Remember you place it in park and power down. Do not lock emergency brake. It sure does improve your average miles per gallon using the Prius for side trips and moho for basic traveling. Good luck.
JohnnyT
Goshen New York
Moved from class A forum
Peralko
San Antonio, Texas
The regenerative function in a Toyota hybrid drive comes from one of two electric motor/generators incorporated into the hybrid synergy drive (HSD). The HSD functions as a transmission that drives the front wheels. There are no regenerative function in the rear wheel assembly.
And yes, the Prius can be safely towed with the front wheels off the ground, accordingto the owner's manual.
Peralko
USAF Retired
95 Country Coach Affinity
2008 Honda Civic hybrid
2004 Honda GoldWing
Drew&Corinn
Pleasant Grove, Utah
Peralko... can your civic be towed 4 down?
Thanks,
Drew
2005 GMC Sierra D/A Crew Cab,Airsprings,4 inch AFE intake-exhaust, Edge w/Attitude+More
2005 Fleetwood Revolution40e
Soon to be Ex-Wife Gets - Cardinal 31BHLE (Maple),4.2 LP
2006 Polaris Ranger XP Browning
2-2008 Polaris Sptsmn 90s
CANAM 800XP
