RV.Net Open Roads Forum: Towing: Bumpy ride with a pop-up
Search only in Towing
Open Roads Forum  >  Towing
 > Bumpy ride with a pop-up
Pete D
Washington
Posted: 03/31/08 08:08pm Link  |  Quote  |  Print  |  Notify Moderator
UVW of the trailer seems to be almost 2,500 lbs. Add a couple of hundred pounds to that and it's about 3,000 lbs.
What does your owner's manual say about towing trailers over 2,000 lbs and the need for a WDH?
1998 Ranger 4.0 4x4
1991 Scamp 13'
bid_time
Michigan
Posted: 04/01/08 06:15am Link  |  Quote  |  Print  |  Notify Moderator
a WDH may not be "Needed" but it will sure help in stiffening up the ride.
Dogarms
California
Posted: 04/02/08 04:20pm Link  |  Quote  |  Print  |  Notify Moderator
Our Coleman Cheyenne (about 3,000lbs.) was miserable to tow with my truck because it bucked and kicked on anything but a smooth surface. In contrast, our 11,400 GVW Arctic Fox is much smoother. The Coleman behaved better behind our Honda Odyssey. I guess the Honda's soft suspension was more compatible with the buckboard springs on the popup. A WD hitch might help, but remember, they work both ways; you're also putting some of the truck's weight on the trailer.
TC
'03 GMC ExCab, SB, Duramax, Allison, 4x4, Husky mudflaps, Procaps, Bilsteins, Leer shell, BedRug, Oilguard Bypass,
Caterpillar fuel filter, ISSPRO EV Pyro and Boost guages, Titan V, Equal-i-zer EQ1400, Arctic Fox 30U
