RV.Net Open Roads Forum: Tow Vehicles: JEEP WRANGLER TOW VEHICLE ?
Search only in Tow Vehicles
 > JEEP WRANGLER TOW VEHICLE ?
mountainborn
Ouachita Mountains, Deep in the Arkansas Outback
Posted: 03/28/08 05:46pm Link  |  Quote  |  Print  |  Notify Moderator
In this photo of the tongue fully extended, the bolt holes where the generator and mount are attached are visible. Should a instability situation arise, it is a simple matter to loosen two bolts and set the whole thing in the tow vehicle or the travel trailer.
08' Oliver Legacy Elite with 4" lift axle
08'Jeep Wrangler with no lift
www.oliverforums.com
www.mountainborn.com
airduds
Homosassa, Fl
Posted: 03/29/08 02:44am Link  |  Quote  |  Print  |  Notify Moderator
airduds
Homosassa, Fl
Posted: 03/29/08 02:51am Link  |  Quote  |  Print  |  Notify Moderator
For stability, more distance between the hitch and the trailer axles is better. Less distance between the axle and the rear of the trailer is better.
For a TT, less distance from the rear axle of the tow vehicle to the hitch is better.
mountainborn
Posted: 03/29/08 06:18pm Link  |  Quote  |  Print  |  Notify Moderator
I was hopeing to hear from others that tow with a Wrangler. Here is a link to a video that shows the instrument panel readings while towing at interstate highway speeds. Over the dashboard, through the bug splattered windshield as the sun comes up, showing the, RPM, Average Fuel Mileage, Speedometer, ect..
Sunrise I-10 Eastbound
mountainborn
Posted: 04/09/08 06:54am Link  |  Quote  |  Print  |  Notify Moderator
The extensible tongue shows up well in this photo. Normaly the 3000 watt Yamaha generator and the mount / cover sit on the tongue.
Photo taken on Historic Old Route 66:
EDIT: add correct photo
* This post was edited 04/09/08 07:13am by mountainborn *
