jdpresslasvegas
Las Vegas, Nevada, USA
My motorhome has an installed propane quick disconnect fitting for using a gas barbeque. Has anyone purchased an adapter and hose that will permit the use of the coach propane for a table top portable barbeque that normally uses a propane cannister?
Bob
Rosher
Tyler, Texas
Almost any local propane dealer should have the hose that connects from a propane tank to a device that was designed to accept the disposable bottles. That is where I got mine.
Allegro 32 BA
Jeep Liberty Toad
Buster, 3 lb. Yorkie
jdpresslasvegas
Rosher:
Thank you for the tip! I will go to the local propane supplier today.
kd7cxg
McMinnville, Oregon
CW has hoses and adapters
2002 Winnebago Brave 30W 8.1L
2004 Jeep Liberty W/US Gear Braking System
1999 Bichon Frise (Guard Dog)
Brazels Ultra Power Mod
Good Sam Lifetime Member
FMCA F277504
Tom N
Sarver, PA/Crystal River, FL
If you don't have a regulator on your grill your adapter has to come off the low pressure side of your motorhome line.
-Tom
"The people that don't believe in evolution are the ones who need it most!"
Sarver, PA/Crystal River, FL/Indiana, PA
2005 Itasca Suncruiser 38R 38' 11"
W24, Allison 2100MH, full body paint
2008 Honda Odyssey EX-L, Roadmaster Sterling bar
FMCA 335149
five'er
Muskoka, ON
Sorry, I don't think that will work for you. I spent many of hours questioning and searching. Those Quick connects are low preasure as they fall after the trailers regulator and I've been told many times that it's not enough preasure to open the regulator on a tabletop stove or BBQ. The only sollution I've been provided was to "cut in" before the trailers regulator and create my own quick connect OR find yourself a BBQ that doesn't have a regulator or one that you're able to bypass without blowing yourself up. I decided to just get myself a 10lb propane tank, 2 hoses and a T valve. When I set up I hook up both the stove and BBQ to the tank and I'm good.
I tried to just get the part and test it for myself but the guy at the propane store got pretty upset after explaining it to me multiple times and claims others have tried and failed. If it works for you let me know.
2006 2500 Cummins Dodge Mega Cab, Jacobs Exhaust Brake, 16K Pullrite SuperGlide, Prodigy Brake Controller, 2007 Coachman Chaparral 340QBS
tallyo
Fort Myers,Florida
I had one on my previous coach and it worked fine. I installed one on my new coach and it doesn't always work fine.
I have read where you need to turn the gas on slowly then it works. Apparently turning the gas on too fast has an adverse affect. Don't ask me to get technical here because I have no idea .
I haven't tried it yet but will when we leave next month on our trip.
Tallyo
2007 Winnebago Adventurer
W-24, 6 spd Allison
Saturn VUE w/ Brake Buddy Vantage
Drinks-6, Eats-4, Sleeps-2
Semper Fi
ramrunnr
Randleman, NC, USA
tallyo wrote: .....I have read where you need to turn the gas on slowly then it works. Apparently turning the gas on too fast has an adverse affect. Don't ask me to get technical here because I have no idea .....
If you open to fast it causes the Dussenberg compisator to bind in the Hysen-Duetz rail.
tallyo
Fort Myers,Florida
ramrunnr wrote: tallyo wrote: .....I have read where you need to turn the gas on slowly then it works. Apparently turning the gas on too fast has an adverse affect. Don't ask me to get technical here because I have no idea .....
I knew there was a very reasonable explanation....... now how do you spell Dussenberg compensator?
Ray Witt
Stillwater, Okla
you can buy a regulator at camping world it will come with instructions, hose and all. Very easy to install and works great. Have had one for the last 8 yrs. Good Luck Ray.
