RV.Net Open Roads Forum: Class A Motorhomes: After the tanks are dumped..
 > After the tanks are dumped..
Page of 5
joppa
Massachusetts
Posted: 03/30/08 05:55pm Link  |  Quote  |  Print  |  Notify Moderator
I always add some water a dash of aqua chem and a couple of cups worth of calgon
The World is a book, and those who do not travel read only a page. ~St. Augustine
2007 Foretravel Nimbus
Cummins ISM 500HP
Allison MH4000w/Retarder
klenger
Tucson AZ
Posted: 03/30/08 05:57pm Link  |  Quote  |  Print  |  Notify Moderator
I was told to add a bit of RV antifreeze becasue it helps to lubricate the seals in the dump valves. I used to do that when I lived in Colorado and had RV antifreeze on hand, but since I almost never winterize here in AZ, I don't bother keeping any around. I do try to add some water though.
2008 Tiffin Allegro 32BA FRED Class A Motor Home
2008 Honda CRV, Blue Ox, SMI DUO Stay-in-Play Brake
mcc1229
Piedmont NC
Posted: 03/30/08 06:16pm Link  |  Quote  |  Print  |  Notify Moderator
Five gallons of water and Toss in a orange deodorizer
Chuck&Gail
In the Colorado Mountains
Posted: 03/30/08 06:23pm Link  |  Quote  |  Print  |  Notify Moderator
We add about a gallon in each tank after dumping. No trouble in over ten years, so I'll keep doing it. We dump every time we leave the CG.
Chuck
Wonderful Wife
Lovely German Shepherd.
1999 Mercedes ML320 TV
2003 Wanderer 187TB Toybox (3620# UVW, 4800# loaded)
Not yet camped in Hawaii, 2 Canada Provinces, & 2 Territories.
Big_Eck
Cold Canada
Posted: 03/30/08 06:32pm Link  |  Quote  |  Print  |  Notify Moderator
Good advice keeps things liquified
2004 Holiday Rambler Endeavour 40 foot 3 slides
10 year friend of Bill W
Driven over 200 New units of all kinds and descriptions
"...there are two types of rv'ers, those that camp and those that camp at a NASCAR race..."nascarcamping.com
tallyo
Fort Myers,Florida
Posted: 03/30/08 06:37pm Link  |  Quote  |  Print  |  Notify Moderator
I always add water after I dump. Sometimes I throw ice cubes down the toilet and as we travel they bang around knocking off stuff stuck to the sides of the tank.
I backwash my tank everytime.
Tallyo
2007 Winnebago Adventurer
W-24, 6 spd Allison
Saturn VUE w/ Brake Buddy Vantage
Drinks-6, Eats-4, Sleeps-2
Semper Fi
Timbo08
Houston Texas
Posted: 03/30/08 06:55pm Link  |  Quote  |  Print  |  Notify Moderator
I'm kind of "anal" :about the holding tanks. After I dump them I refill several times until clear water comes out.
WBVenard
Bernardsville, NJ
Posted: 03/30/08 07:05pm Link  |  Quote  |  Print  |  Notify Moderator
I always try to dump with the black water tank at least 2/3 full. If it is not that full, I put more water in while hooked up to the city water. I can easily do this by connecting a dedicated black water hose with check valve, directly to the black water tank. This way it gushes out fast and takes most of the solid stuff out with the water, other wise a lot of the solid will stay in the tank, and if you do not add water it will dry out and become difficult to impossible to get out. I then refill the black water tank to at least 2/3 full and drain it again. While filling the tank, there is a sprayer inside the tank that is supposed to clean the inside of the tank. I do this part without a pressure reducer on the hose for maximum pressure.
I also have a clear plastic section in the hose at the exit of the tank so I can see when there is no more solid or toilet paper coming out. After the 1st dump and then the rinse, it is always coming out clear. Then I dump the grey water tank to clean out the hose.
Right away after that, I put the aqua chem in the toilet and flush it 2 or 3 times to keep what ever might be left in the tank soft and to keep the inside oder free. I have not added soap or a lot of water and it has worked for me.
One other idea I read somewhere is worth repeating. Most RVers hook a hose from city water to the black water tank to fill it for rinsing. There should always be a check valve to prevent any bad stuff from getting back to the city water faucet, (most if not all tanks have a check valve built in), but I always carry a spray bottle filled with bleach and water mixture (guess at ratio and intentionally make it strong) to disinfect anything that could possibly get back to the city water faucet, before I hook up.
If you have watched other campers like I have, you undoubtedly have seen some of them get very sloppy with their procedures. I have seen sewage dumped all over the camp site. Not a nice thing to happen. Good idea to make sure your 4" hoses are well connect together, or that much water gushing out at once can blow two hoses apart. I've seen it happen to other many times. I try to be smart enough to learn from others mistakes instead of my own.
Happy Trails,
Wally
Wherever I happen to park
Posted: 03/30/08 07:14pm Link  |  Quote  |  Print  |  Notify Moderator
Depends. Black tank I will usually add a bit of water. Gray, I don't. But there are two conditions:
When I'm living in the rig, I'm going to be adding water to the tanks right soon anyway, so why bother. The only time I need to add is when I'm moving out of the RV for a while.. This is one of only two times I add "Stuff" to the tanks (A biological in both cases) and this "Stuff" needs added water to work properly, so I add water
The other time I add "Stuff" is when I'm dry camping
jerry David
portland, Ore
Posted: 03/30/08 07:43pm Link  |  Quote  |  Print  |  Notify Moderator
When leaving a rv site always empty ice cube box in toilet and add
dish detergent. Also put a cup of dish detergent in grey water. Buy it
at costco in bulk, keeps it clean and smelling good. Get some soap
suds when dumping the next time.
Jerry David
Page of 5
