RV.Net Open Roads Forum: Travel Trailers: filling toilet
 > filling toilet
newbie5
canada
Posted: 03/31/08 12:20am Link  |  Quote  |  Print  |  Notify Moderator
What hose do you use when filling your toilet when there is not enough black water in your tank?
TPLynch
Arizona
Posted: 03/31/08 12:30am Link  |  Quote  |  Print  |  Notify Moderator
I don't use a hose. I put some water in the tank via my Flush King after I'm finished dumping. I look down the toilet (from inside the RV) with a flashlight until there's enough water in the tank to sufficiently cover the bottom of the tank. The other method I've used is to flush the toilet (holding the pedal down) until the bottom of the tank is covered with a few inches of water.
2007 Chevy 2500HD 6.0L 4.10
2008 Jayco Jayflight 29BHS
chevyman2
missouri
Posted: 03/31/08 01:06am Link  |  Quote  |  Print  |  Notify Moderator
I dont have much problem with tank flushing. #1 == No POOOOOO in coach!!!
#2 == I only camp on weekends and my typical 1 weeks vacation. So I use the flush lever to fill tank with water (At least 2") then let er drain.
#3 == When we PEE, we hold flush to pour in lots of water at that time also.
>>>>>>>I think if I used mine for longer periods at a time. Id buy a flush king and use it regularly.
Tim, Kathy and Ken (son)
03 JEEP Grand Cherokee,04 AVEO-DD, 94 FIREBIRD
07 Coachmen 32FKS stays at campground***AT LEAST I CAN MOVE IT MYSELF NOW***
IF your going to be on a horse in a desert --- AT LEAST GIVE IT A NAME
TOTAL NIGHTS CAMPED IN 07 = = 62
Sportsman2505qss
Winter Springs, Fl USA
Posted: 03/31/08 05:00am Link  |  Quote  |  Print  |  Notify Moderator
I purchased what I call a doughnut at Camping World. It fits into the toilet and keeps it open so the water flows. I do other things and just check on it once in a while.
Click
2002 KZ Sportsmen 2505qss bought in 2001 1999F-150
Gamble Rogers
Bumpyroad
Virginia
Posted: 03/31/08 05:06am Link  |  Quote  |  Print  |  Notify Moderator
I use a standard green/grey garden hose, not the white drinking water one myself.
bumpy
H & E
North Texas
Posted: 03/31/08 05:20am Link  |  Quote  |  Print  |  Notify Moderator
If dumping I use a gray hose to attach water to to flush system. Always use a little extra water during normal use. Wife also dumps some dish water in while camping as the black tank usually has more available capacity than the others.
Campin'Deb
Milford, CT
Posted: 03/31/08 05:25am Link  |  Quote  |  Print  |  Notify Moderator
Hi Newbie,
I sometimes just stand there and hold the handle halfway to fill up the bowl a few times or fill a bucket in the sink and pour it in.
Deb & Cathy
Shilo Ann - 10 yr old Xolo
Milford, CT
2006 Puma 29FKSS
MoTerry
Missouri
Posted: 03/31/08 06:07am Link  |  Quote  |  Print  |  Notify Moderator
I use the shower hose to run extra water in the toilet. Just take off the showerhead and let the water run.
Another hint. With the showerhead on, it makes toilet clean-up easier at times too.
MoTerry
rhondavid
Birmingham, Al
Posted: 03/31/08 06:09am Link  |  Quote  |  Print  |  Notify Moderator
Second the use of the shower hose. Fast, easy and simple.
David,Wife,4 kids,SIL,1 grandchild
2003 Ford Excursion Eddie Bauer 7.3 PSD w/3.73 rear end
Jayco Kiwi Too 30T bunkhouse w/triple bunks
Prodigy Controller
Reese Dual Cam HP
Michelin LTX M/S
Topsail Hill Cult Member
thenkler
Goshen, NY
Posted: 03/31/08 07:19am Link  |  Quote  |  Print  |  Notify Moderator
Another tip I got from somewhere else is to dump a bag of ice in the tank just before you hit the road. Then dump at your next destination if possible, at very least it has knocked some solids loose and mixed them up.
Hey no frosty jokes now!
2007 Jayco Feather LGT 30R
Yukon XL Denali
Me, DW, 5 Kids
 > filling toilet
