RV.Net Open Roads Forum: Tech Issues: Gas or propane
 > Gas or propane
sreed29
river rouge, michigan
Posted: 03/31/08 06:40pm Link  |  Quote  |  Print  |  Notify Moderator
I'm looking to get a 5500 Onan generator installed in my 08' Montana. Except for the price difference. What are the advantages and Disadvantages of gas vs propane. Thank You Steve
tom_kat
way upstate new york/lake george area
Posted: 03/31/08 06:47pm Link  |  Quote  |  Print  |  Notify Moderator
generators use a lot of propane compared to gas ,
1985 Class A Holiday Rambler Imperial 33 +1979 Class C Holiday Rambler Statesman 1000 = 24 ft
mike4947
N. Syracuse, NY
Posted: 03/31/08 07:48pm Link  |  Quote  |  Print  |  Notify Moderator
A lot depends on the propane storage capacity. For 20/30 pound cylinders forget it. For the average 14 gallon tank figure weekends are OK even with the genset running all the time. Over that it's break down the site and drive to find a propane dealer.
Larger tanks of course extend your stay.
If you normally camp with hookups and will see very limited use of the genset then propane is what our folks get. Less problems in storage. For a lot of usage such as boondocking/dry camping our folks go with gasoline as it's easier to get without moving and locating.
blog.rv.net Your daily guide to the Open Road
Subscribe to the daily digest
Want to sell some of your gear? -
Free Classified Listings on RV.Net
They say you learn by your mistakes, in that case I must be a genius.
alpineduner
Alpine, Ca., USA
Posted: 03/31/08 08:39pm Link  |  Quote  |  Print  |  Notify Moderator
propane generators are a P.I.T.A
I vote gas
Glamis...why go anywhere else?
crickeydog
Marietta, Ga.
Posted: 03/31/08 08:42pm Link  |  Quote  |  Print  |  Notify Moderator
If you can get a gasoline or diesel fuel tank factory installed in your new Montana, I'd opt for the gas or diesel genset. We have an Onan 6500 Marquis Gold propane genset in our 5'er and we love it but it is not as fuel efficient as a gas genset. A 30lb propane bottle will last us about 12 hours with the generator running at approx 50% load.
Happy camping!!! See ya'll down the road!!!
AIR FORCE RETIRED "EITHER LEAD,FOLLLOW,OR GET OUT OF MY WAY"!
2006 GMC 3500 SLT CC DRW 4X4 D/A LBZ,PREDATOR & FS2500 OIL FILTER
2004 HR PRESIDENTIAL 30 SCD 5'ER.
CHEROKEE & CHEYENNE, MINI DOXIE'S
LOADED LIKE A FREIGHT TRAIN, FLYIN LIKE A JET PLANE!!
427435
Rochester, Mn
Posted: 03/31/08 09:19pm Link  |  Quote  |  Print  |  Notify Moderator
A couple of 5 gallon gas cans can be used to refuel the gas generator. Not so simple with an LP generator.
Mark
2000 Itasca Suncruiser 35U on a Ford chassis
2003 Ford Explorer toad with US Gear brakes,
ReadyBrute tow bar, and Demco base plate.
gunny357
North Carolina
Posted: 04/01/08 04:04am Link  |  Quote  |  Print  |  Notify Moderator
I'd go with propane.
Never worry about a gummed up carburetor.
Generator will last longer.
Little or no smell from the exhaust.
Same fuel as your furnace/water heater/stove.
Not storage hassles
Just get larger tanks installed on the front side as a gallon of propane doesnt have as much energy as does a gallon of gas so you will be using about 25% more.
Propane is cheaper than gas, even though you use a little more of it.
Wherever I happen to park
Posted: 04/01/08 08:42am Link  |  Quote  |  Print  |  Notify Moderator
If you have a trailer you already have propane tanks, You would have to add a gas tank though, Gas is a hazardous material so, why add more.
Generators use a lot of propane though
If you have a motor home..Well, I carry 27 gallons of propane (max) and 70 gas, of which about 50 is shared between the main engine and the Onan. a gallon of gas is more power than a gallon of propane. So the math gets real easy
cabanaman
middleburg florida
Posted: 04/01/08 09:18am Link  |  Quote  |  Print  |  Notify Moderator
I very rarely use my generator.it's just for power outages or the even rarer boondocking.So I elected to go with propane cause there is no residual fuel clogging the jets issues.Long layoffs don't bother it.
Retired Navy
2007.5 Dodge Ram SLT sport 2500 quad cab 6.7 cummins,6 speed auto with exhaust brake.
2007 Open Road 378SA4S-5 quad slide.
cabanaman
middleburg florida
Posted: 04/01/08 09:20am Link  |  Quote  |  Print  |  Notify Moderator
Getting propane tanks refilled is no problem,heck most convience stores around here even have them for exchange for $18.
 > Gas or propane
