BigJon05
Ripon
On my way home from weeklong Pismo trip, 1 mile from storage the leaf spring hanger broke on my trailer. The connector tab broke off of the triangle and the spring is now wedged up against the frame. I've got a phone pic I'll try and post. Have extended warranty and the trailer place is giving me the run around. Called eclipse with no call back in a week.
05 Eclipse Attitude 26'FSAK
03 F350 PSD longbed, 6" lift BFG 35
08 Polaris RZR
07 Can-am Outlander 650 MAX XT
2 Can-am DS650 00/01
1 TTR 90
1 Redcat 110
1 Unison 50
1 Honda XR50
dbbls
Missouri
My experience has been that some extended warranty places exclude suspension parts. I know Good Sam CPS does. Hope yours is different. Good luck.
1999 F250 Superduty, V10 with Banks Power Pack
2004 Colorado 29RL 5th wheel with 3600 watt Onan
Chris&Lori
Lilburn, GA
It’s probably not going to be warranted by Eclipse or the dealer and like DBBLS said, usually extended warranties don't cover frames. If you look at your warranty paperwork, it will probably be covered by the frame manufacturer’s warranty, that is if it hasn't expired yet. I think that Lippert made your frame with a 2 year warranty.
Good Luck!
Chris, Lori and the Greyhounds
94' Dodge Ram 2500 4X4 Cummins T/D
05' 30' Coachman Capri
BallsDeep
Thousand Oaks, Ca
I had the same issue on my Sierra Sport. I ended up calling the company that manufatures the chassis and they ended up sending me everything for free so that I could fix it myself.
amberjax
Suffolk,VA.
What extended warranty company did you go with?
I just purchased one from Interstate and according to the leaflet that they gave me they cover the following listed under "suspension":
Wheel bearings, coil and leaf springs, shackles,shackle bushings, spindles, spindle supports, axle shafts, actuators.
Hope this might help someone.
code3run
S. CALIFORNIA
Please keep us posted on the handling of this issue.
Thanks
2008 ATTITUDE 21AK
2007 Dodge Ram 1500 hemi 5.7 lit
07 Yamaha ttr 50
07 Yamaha ttr 90
07 Yamaha ttr 125
16 FT Wellcraft -------Sold
2 boys 8 and 11 and wife
No dogs
BigJon05
Ripon
Yeah I called the dealer, eclipse and lippert. No one wants to help since the trailer is now 3 years old. I took a second look and it appears that only the 2 clips that bolt through the bracket that holds the 2 leaf springs together broke. So I should be able to fix it myself. I'll post pics afterwards.
I am also trying to track down my paperwork for the extended warranty. If its in there and the dealer turned me down... well let's just hope that doesnt happen.
Dirtclods
Newport Beach
If this is an Eclipse problem let's voice it it here! And let others know.
Toy-hauler
NorthWest
No, it is not only an Eclipse problem. It is a Lippert problem. My new KZ broke a rear spring mount last night at the top of a pass. Pulled into a DOT equipment storage yard. Emptied out my stuff and left it behind and drove 3 hrs home. KZ has called me many times today already. They gave me the GM's name and # if things can't get handled at the dealer level.
08 F-450 Red Lariat 08 KZ Inferno 3912 - 24k Superglide with under bed rails sitting in garage not going to be used, what a shame.
DuneMe
Elk Grove, CA
Bummer!
I had seen one of those issues on a Glamis Dunes Forum post.
Make sure you have lube in there. If they are dry, I think you'll have a tough time getting any warranty. Kinda like saying I have a 100,000 mile warranty on my car so I never change the oil!
2005 GMC Sierra 4X4
Duramax Diesel - Edge w/ Attitude / 4" exhaust / Cold Air Intake
45-gallon TransferFlow Tank
4" Lift
Air Bags
Weekend Warrior LE3905 Toy Hauler
TomPro Mini-Rail - Turbo Hayabusa
Raptor 700's for the Wife and I
250EX - Daughter's
