RV.Net Open Roads Forum: Travel Trailers: Costco's Kirkland toilet paper
 > Costco's Kirkland toilet paper
Poohper
Saugus,ca
Posted: 04/01/08 10:36pm Link  |  Quote  |  Print  |  Notify Moderator
Hello,
We just purchased our first Keystone Springdale Travel Trailer and was told that we could use the toilet paper from Costco as it is ok for the septic tank. Does anyone use this paper in their rv bathroom? If it's not good , then what should we buy?
Thanks!
Pooh
wrenchbender
Phx
Posted: 04/01/08 10:44pm Link  |  Quote  |  Print  |  Notify Moderator
I have used their TP for 30 yrs in my home, boat, and TT and never had a problem.My home is also on septic.
Poohper
Saugus,ca
Posted: 04/01/08 10:46pm Link  |  Quote  |  Print  |  Notify Moderator
Thanks for replying so quickly, we are going camping on Thursday and I wanted to make sure I had the right information.
F1bNorm
Gardena, CA
Posted: 04/01/08 10:56pm Link  |  Quote  |  Print  |  Notify Moderator
Works fine, except for the space the other rolls take!
F1BNorm
fordsooperdootydieselsmoker
OrangeCountyCalifornia
Posted: 04/01/08 10:57pm Link  |  Quote  |  Print  |  Notify Moderator
Do not use 2 ply embossed Costco TP. Depending on how your black tank plumbing is ran, if it has some bends, you will have issues. Use only single ply. The test is to put a single sheet in a glass of water, see how long it takes to disintegrate. Compare single ply with 2 ply. If they both fall apart at the same rate, then OK. The only time we had horrible issues was 3 years ago when "someone" grabbed the Costco 2 ply by mistake. This is especially important if you have children, and ours always go with. Plus the ladies seem to use more than the guys, and clogs are a great way to ruin your always unpleasant enough dumping experience! Use plenty of water when flushing, too!
Poohper
Saugus,ca
Posted: 04/01/08 11:03pm Link  |  Quote  |  Print  |  Notify Moderator
We always have our kids with us but I will have to test the paper before we use it . I better bring both kinds just in case.
Thanks!
robbins
Sonora, Ca
Posted: 04/02/08 12:02am Link  |  Quote  |  Print  |  Notify Moderator
Try this info. It is here on this forum.
The Toilet paper Test
See 'ya on top
Keith
2004 2500HD silverado 4x2 extra-cab
265/75/16 Hercules tires
Reese 15000 Pro Hitch
2006 Gulf Stream 30FBRG
2oldman
WA
Posted: 04/02/08 12:09am Link  |  Quote  |  Print  |  Notify Moderator
Toilet paper search including Costco
lat471
Lebanon, PA
Posted: 04/02/08 05:31am Link  |  Quote  |  Print  |  Notify Moderator
Use any toilet paper you want. It's not as much the tp as it is the amount of water.
07 Cameo LXI F35FD3
R Taj-We-Haul
Pappy John
Lower Susquehanna Valley
Posted: 04/02/08 06:28am Link  |  Quote  |  Print  |  Notify Moderator
Bingo!
2008 Sunset Trail 29RL
2007 Tundra Double Cab 4x4 5.7L
Reese Dual Cam
