fla-gypsy
North Florida
docdialtone wrote: God I love this site, 7 replies in 13 minutes!  I guess I'll leave it hooked to the truck then!
This is the best way. The change out is very easy to do and you will kick yourself for not doing it sooner
05 Super Duty XLT CC 5.4/3.73 5 sp auto Torqshift
06 Keystone Hornet 29 RLS/(The"Cracker Cabana")
Reese HP Dual Cam
Camping Photos
Northeast Florida Camping Club
St Andrews SP cult member
BAJA X
Minnesota
Leave it hooked up to TV in my eyes its the safest way and in half hour your good to use your new power jack, best invention for a travel trailer in my opinion.
08 F-350 4X4 Crew Cab Lariat Super Duty V-10 Tow Command 4.10
Tow Beast Receiver 1700# Reese W/D Dual Cam sway
08 XT30SB CrossRoads CrossForce
04 650 Baja X
04 400 XT Outlander
89 Springer Softail
pete42
Jamestown, Ohio
Hey John I use to fly jump planes and I would ask myself why anyone would want to jump out of a perfectly good plane just because the door was open.
The hardest thing I had to do was close that stupid door, You have to slip the plane to the right lean over and throw the latch, I had to let go of the wheel to reach the latch while doing this and I would some times ask just who is the dumbest?
Chuck&Gail
In the Colorado Mountains
When I did mine I used the TV WD hitch to hold up the TT. Worked real easy.
Chuck
Wonderful Wife
Lovely German Shepherd.
1999 Mercedes ML320 TV
2003 Wanderer 187TB Toybox (3620# UVW, 4800# loaded)
Not yet camped in Hawaii, 2 Canada Provinces, & 2 Territories.
allenruger
Foster, KY
Hey guys. Really new here but I've been lurking for a little while. Looks like everyone is very helpful on here. I've had my travel trailer for 5 years and still have a manual front jack but have always been interested in an electric one. So, how difficult is it to change it? (I'm no handy man. ha!)
2003 25ft. Dutchman Sport
2005 Silverado 2500HD Extended Cab 4X4 6.0
lat471
Lebanon, PA
Three bolts to remove. Lift the manual jack out of the a frame. Clean the a frame of rust and paint. Put the electric jack in. Replace the 3 bolts and run a the wire to your battery. That's about as straight foward as you can get. Now remember to keep the manual jack some where so you can swap back if you trade your unit. Whew I had to watch how I phrased those instructions.
07 Cameo LXI F35FD3
R Taj-We-Haul
allenruger
Foster, KY
lat471 wrote: Three bolts to remove. Lift the manual jack out of the a frame. Clean the a frame of rust and paint. Put the electric jack in. Replace the 3 bolts and run a the wire to your battery. That's about as straight foward as you can get. Now remember to keep the manual jack some where so you can swap back if you trade your unit. Whew I had to watch how I phrased those instructions.
Now, even I can handle a project like that. Thanks for the info. and the quick response! Yeah, I can see where you had to be careful with the wording on those instructions. ha!
PWH1970
Iowa
I'm thinking of adding one too. I see some have 2 inch tubes and others 2.25 or 2.5. Will they all "fit" on any trailer? I plan on going with the most powerful one I can in case I trade up someday.
TIA
mikeyork
Garland, Texas
I haven't worked on a lot of different TT's but what I have seen seems to indicate that the actual hole through the A frame is the important dimension and most will accomodate any of the electric jacks you will find. The biggest challenge on mine was that the battery tray is mounted just behind the jack and the mounting plate on the electric jack overlapped the battery mount by about half an inch. I ended up using a ginder to take some off the back of the plate. But, including grinding, repainting and mounting it only took about an hour to do. Also, putting it on the TV seemed the safest way to go for me. The wife absolutely loves it. I also recommend putting as big of one on as you can. I put a 3500# one on mine and it makes lifting the rig so much easier for connecting the WD hitch.
2008 Jayco Jay Feather 311
2008 Ford F-250 Lariat SD, 4 X 4,Crew Cab, 6.4L Diesel, Automatic, Trailer Tow Package
Equal-I-Zer WDH
'07 Nights camping = 36
'08 Nights camping = 34 (so far)
coolcamp
St. Louis
Don't work on your own trailer...you're going to kill yourself. Pay someone to do it safely...if you have to ask these types of questions you're not capable of performing the work.
