RV.Net Open Roads Forum: Truck Campers: Need help with a camper purchase
 > Need help with a camper purchase
milo12
CA
Posted: 04/03/08 09:03am Link  |  Quote  |  Print  |  Notify Moderator
I have found the camper I want to buy. An Outfitter popup. My dilemma is how to get it home. I have a Dodge 2500 but there are no tiedowns on the truck. I don't want to spend a lot of money putting tiedowns on because the truck is for sale. My next truck will have a flatbed so the tiedowns would be of no use. I looked into buying some at Camping World but the total cost with fastguns is about $1500. Is there an alternative safe way to just get the camper home? I have to move it a couple hundred miles on flat highway.
Mr. Tree
Cincinnati, Ohio
Posted: 04/03/08 09:12am Link  |  Quote  |  Print  |  Notify Moderator
Load it and without tiedowns drive very slowly and carefully home. It won't go anywhere. You might have a friend follow you in a car and with his cell phone let you know if something seems wrong.
See you soon on the American Road.
1973 Ford American Road 11.5' Camper with 500,000 enjoyable miles.
1985 Ford 250HD, 6.9Diesel/4-speed/3.54 limited-slip axle, Supercab, SRW. Consulting forester, Supervisor of SWCD, and NRA Life Member.
A city without trees ain't fit for a dog!
Moomba2002
Sebastopol, CA
Posted: 04/03/08 09:43am Link  |  Quote  |  Print  |  Notify Moderator
If you can find a place for the ratchet type straps to hook onto that would be sufficent. I had to do that with a larger camper and it worked out fine. Good Luck.
1999 Ford F350 DRW 4X4 PSD 6spd.
Banks Stinger Package
Fords upgraded Air Intake System
ExtremeAire 150 PSI 100% Duty Cyle on board air w/4gal. tank
Air Bags & Rancho 9000's
2003 Arctic Fox 1150 loaded except solor
DonCurley
La Sal, Utah
Posted: 04/03/08 09:45am Link  |  Quote  |  Print  |  Notify Moderator
On the assumption that you are purchasing a new or used camper directly from Outfitter, keep in mind that they routinely deliver their campers around the country. I suggest checking with them to see about this option.
* This post was edited 04/03/08 10:34am by DonCurley *
-'07 Dodge 3500/QC/SB/SRW/4x4/6.7L CTD/6-spd auto/35" Toyo M/T's/Ride-Rite air bags/RS9000XL shocks
-'07 Apex 8 fully optioned w/220W solar/2 T-145's/2KW Prosine/Honda EU2000i/Tundra fridge/AC/etc
-'00 Jeep Wrangler TJ 4x4, highly modified w/5.9L Magnum V8
dav1550
Catawba River Basin
Posted: 04/03/08 09:54am Link  |  Quote  |  Print  |  Notify Moderator
FWIW
Had some what of the same trouble.......and was able to drop it down on a utility trailer to tow it to the house.
Dave
Photog101
Garden City, Michigan
Posted: 04/03/08 02:38pm Link  |  Quote  |  Print  |  Notify Moderator
How about a Belly Bar? Easily installed and removed and usually universal from truck to truck.
"Doc"
Combat Vietnam Veteran Support our troops for serving our great country.
CLass "A"='90, SunBus, Oshkosh, 460, C6, 5.12 gears, 8R19.5.
New TV='02, K3500, CC, DRW, 8.1L, Allison, 4.1 gears.
Pace 8518TA2 Trailer. Looking for a side entry T/C with no slides.
B-n-B
Central Coast, Kalifornia
Posted: 04/03/08 02:44pm Link  |  Quote  |  Print  |  Notify Moderator
Cargo straps.
2000 F-350 PSD Super Cab 4x4 SB
...searching for our next TC
1979 Scout II - All that and a bucket of chicken.
"RV.net, let the drama begin."
Sportsman Matt
Blackstone, MA
Posted: 04/03/08 03:24pm Link  |  Quote  |  Print  |  Notify Moderator
Check eBay, usually you'll come across Universal "Belly" Tie Down Bars for anywhere from $20.00 to $100.00. Then just go to the hardware store and buy some heavy turnbuckles. That should solve the problem. I wouldn't recommend ratcheting tie down straps, they tend to stretch and open up at times.
Worse case buy a universal kit and put it in yourself, then put it on eBay when your done.
Good Luck
Matt
Life is short, Play harder.
2002 GMC Sierra 1500 Regular Cab Long Bed 4.3L V6 Automatic 2WD
1989 Sunline C-750 Slide In Truck Camper
7'6" Floor, 11'6" OAL
Fishing and Hunting New England and eventually the world
phoenix827
torrington, ct
Posted: 04/03/08 04:58pm Link  |  Quote  |  Print  |  Notify Moderator
Check "here". I am updating it now.
milo12
CA
Posted: 04/10/08 01:31pm Link  |  Quote  |  Print  |  Notify Moderator
Thought I would give an update.
I met the owner to look at the camper and guess what? He reads this forum and knew of my dilemma. Well, we arranged so he will deliver the camper to me. You meet some great people on this forum.
I have decided to forget the flatbed route, maybe someday. Thanks for the Ebay advice. I looked on Ebay and found Torklifts and turnbuckles for 100's less than anyplace else.
So, soon I hope to be out on the road with my new rig. I'll be they guy with the grey Dodge, Outfitter camper, 2 crazy dogs and a big smile.
