Circleearth3
Mayberry
Where's the fire ?
What's the rush ?
Are you entering the Pikes Peak mountain climb in YOUR MOTORHOME ?
Are you retired ?
If this is a serious question. You need to do more research.
J-Rooster
Port Orchard, Wa. U.S.A.
Here Kitty Kitty Kitty C-15 Cat! I've driven them all over the road, and logged over 4 million in doing so and in my opinion it's Cat power! John
Drew&Corinn
Pleasant Grove, Utah
Well... Lots of opinions... I am actually purchasing what I am due to the fact that it is rated to tow 15,000 lbs. Without that on it should do well and I have learned something myself from all of you comments... Thank you. My rig was dynoed at 435 HP on a C9. They turned it up back at the chassis plant. I think you can turn a lot of these up quite a way depending on the cooling. Side radiators Yeah!
edited 04/04/08 04:43am by an administrator/moderator *
CaBoy
Junction City, OR USA
Just one more thought. It better have a he!! of a bunch of snort because even with a 6 speed tranny it better not lug enough or loose enough speed to make it kick down a gear cause then that baby would really be screaming! Would be great to see the look on some folks faces though when he smoked around them.
The older I get, the better I used to be.
1997 Prevost by Country Coach
470 HP Series 60 Detroit / 6 SP. Allison
2005 Jeep Grand Cherokee Toad
Same Co-Pilot for 43 years
2 Boston Terrier girls, Scooter & Mia
SCVJeff
Santa Clarita, CA.
Run THIS and there will be no further conversation...
Jeff - WA6EQU
Deen
Vancouver, WA
firecoach wrote: Even though you might want a big engine with lots of power to get you up and over the hill. Most coach builders only have one or two engine choices for a coach model. Then you will need a transmission to handle that power to the rear wheels. This all comes with a weight factor that must fit the frame rails. Then your axles need to carry the weight of the whole set-up! This big engine will need some fuel lots of it to burn to make that power. Unless you have some new set-up like a train using diesel - electric for power. CSX railroad claims they can go 430 miles on a gallon of diesel!! The biggest I've seen is the 625hp and 1800-1900 torque in 45' coaches!! Best of Luck I think that's freight miles (in lbs.), not actual miles.
Deen - Vancouver, WA
'02 Dutch Star 4090 (41+', triple slide)
435/1200 ISC Cummins/Banks PowerPak
'08 Honda Civic/dolly
'05 Honda Odyssey/dolly
NRA Benefactor Life Member
FMCA f47302s, Life Member: Good Sam,
Newmar DP Owners Group
51st yr of RV'ing
69RoadRunner
VA
It's not a problem. They're already equipping school buses in mountain areas to go even faster than that.
edited 04/04/08 01:32pm by 69RoadRunner *
09 Newmar Ventana 3942
Sully2
Cincinnati
v8q wrote: There's a few that 'might' - A 97-98 36' Foretravel U320 with the 450hp M11 and no slide weighed about 29K. A early single slide CC Allure 32' with the Cummins ISC is pretty light. They are both 'pocket rockets' in the MH world.
A guy can get a 2001 Intrigue 32 footer with the ISL in it and get it uprated now to 425...that might be an eye opener...
2000 Country Coach Allure; Cummins ISC 330 HP; 71/2 - 8 MPG regardless
2002 Jeep Liberty
The Fireball
Fort Myers, Florida
You may be able to do 65 mph on the "hills" on the east coast but the "hills" out west are a different story. With most DPs he'll be passing the truckers and gassers and that's fast enough. Remeber diesel is $4.00 gallon now.
"ONCE A MARINE, ALWAYS A MARINE"
...OoRah...Semper Fi
The Fireball and Missy
Furkids - Skippy & Skeeter
2006 Monaco Knight 38' 4-slides, 330 Cummins
2006 Jeep Wrangler dingy
Two Jayhawks
lenexa ks
Briteskys wrote: v8q wrote: There's a few that 'might' - A 97-98 36' Foretravel U320 with the 450hp M11 and no slide weighed about 29K. A early single slide CC Allure 32' with the Cummins ISC is pretty light. They are both 'pocket rockets' in the MH world. I might be pretty close.
31700#/455hp = 69.6
There is another guy on RVNet, forget his name, who has a Zanzibar with Cat C12, 455hp & he weighs even less than me.
Love that power!
Good morning.
I weigh about 26,000 lbs.
2002 Safari Zanzibar
CAT C12 455/1550
Allison 4000
Saturn Vue w/ReadyBrake
FMCA# 390819
