RV.Net Open Roads Forum: Travel Trailers: Are the plastic slide protectors worth it?
 > Are the plastic slide protectors worth it?
scottcougar
Saskatchewan
Posted: 04/05/08 05:34am Link  |  Quote  |  Print  |  Notify Moderator
I saw at my dealer that you could buy grey plastic strips that you slide under the bunk edges so that when you bring slides in and out it dont damage flooring or rug. has any1 tried these yet? how do they work?
downtheroad
Puget Sound
Posted: 04/05/08 08:18am Link  |  Quote  |  Print  |  Notify Moderator
Here they are.. Slide Out-Slicker
I have heard that they do work. Our slides are not causing any carpet or floor problems, but if they were I would probably give them a try.
If you do decide to get them, let us know what you think.
GMC Duramax/Allison (LBZ)
Komfort 277TS Our Rig Pic
Reese Dual Cam HP
skipnchar
Topeka Kansas USA
Posted: 04/05/08 09:16am Link  |  Quote  |  Print  |  Notify Moderator
Ii don't know if they work or not but seems to me that if your slides are causing damage it would be better to have the slide adjusted because they shouldn't. Good luck / skip
mockybird
Mocksville,NC
Posted: 04/05/08 10:02am Link  |  Quote  |  Print  |  Notify Moderator
no problems here without using them
Gary
Hornet28BHDS
Parker, PA
Posted: 04/05/08 10:06am Link  |  Quote  |  Print  |  Notify Moderator
If your slide is giving you trouble, then go ahead!
2006 Hornet 28BHDS-Bunk House, Dual Slides
2006 Dodge Ram 2500 HD
5.7L Hemi, Factory Towing Package
Reese Brake Controller, WD Hitch and Sway Bar
Life is short, why not spend it in an RV!
SPRING HAS SPRUNG!
scottcougar
Saskatchewan
Posted: 04/06/08 09:44pm Link  |  Quote  |  Print  |  Notify Moderator
no its not. but my trailer is a brand new 2008 and I can see light light marks in rug where slide runs. im just worried that in time itll wear a light path. not only that but im laying laminate down where my lino was and i dont want slide to catch laminate transition piece.
dup4fun
NY
Posted: 04/07/08 05:10am Link  |  Quote  |  Print  |  Notify Moderator
They are a pain to get started. I have to start to bring the room in, then push them under the lip. I have to put weight on the the slider farthest away from the switch and step on the one nearest the switch. If I don't the room will push it out about a foot before it catches. I don't see any diffence using them or not but also it is a new camper. Duane
2008 Jay Flight 30 BHDS 07 Silverado 2500HD & 02 Trailblazer
Me 46 the Boss 43
DD 15 & DD 12
Brichon-Frize
Blue & Gold Macaw
