scooter4
Sunny S. W. Florida
Turd Herder wrote: Flattop wrote: Goodyear Marathons are very, very good trailer tires. Keep them full of air, and as long as you don't pull over 65mph you will be in great shape.
P.S. The 65mph applies to any trailer tire, not just Marathons. It should have the max mph stamped on the side walls.
I hope you're right. I just picked up my righ and it has Marathons... Made in China.
My Heart bleeds for you.
Of all the things I've lost, I miss my mind the most.
azjeffh
Chandler, AZ
I had to replace my 1 1/2 year old Maxxis tires so I chose Marathons. So far they have outlasted the Maxxis but have no idea how long they will go. I do use a tire pressure monitoring system so that gives me a little comfort.
BTW, my Marathon's were made in Canada in 2006.
Jeff
Wonderful wife Robin, no children, no pets, no money
05 F250 Supercab SB PSD w/Tow Command
05 HR Savoy 29RKS
Chris&Lori
Lilburn, GA
pitch black wrote: picked up 5er today, going through the PDI, when I thought about the tires, I went and looked and I about fell to the ground to see Goodyears not the Mission bombs, on the Heartland Big Country, that made it even better, new rig with good tires.
Thats really cool! Glad your happy with the 5er and the tires.
Happy Camping.
Chris, Lori and the Greyhounds
94' Dodge Ram 2500 4X4 Cummins T/D
05' 30' Coachman Capri
ol Bombero-JC
GY Marathons -were- made in the USA - pretty good tire.
Then, went to China - pretty bad tire.
(If you had good results with made in China GYs - guess it's a good tire)
Apparently some are now showing up as mfg in New Zealand (probably a good thing).
However - -IF- you are considering purchasing GYs, make sure you do two things:
1. Check country and date of manufacture!
I had good luck with Marathons also - but tires were about 9 years old - figured
time for a new set (about 3 years ago).
GY was still making Marathons in the US, I was told (after spotting date/s
of 17 months old) that they only did a trailer tire production run once a year.
That was direct from GY. Distributor didn't have anything newer.
For that trailer (15" tires) - went to Cooper tires.
2. Search the forums for "Marathon" and "Goodyear", etc. There have been quite a few "failures". Maybe operator error (under-infalted) - maybe not.
Also - what size/weight is a poster's trailer? My Marathons were on
a 20 ft TT.
Bottom line: Your trailer, your money - your decision.
Jayco - talked to Jayco about tire "choice". GY Marathon is their (acceptable) low bid. (no "upgrades" from factory).
I prefer Michelin XPS Ribs (16" wheels) on the (my) Jayco 5er.
World of diff between the Ribs and Marathons.
Not trailer tires - but makes for an interesting "FYI" -
Google: "Goodyear Kept Tire Problems Quiet:
JC
edited 04/06/08 02:36pm by ol Bombero-JC *
pitch black
newport, TN
forgot to tell, the tires are size 16, load range E, and 80 psi max
05 Chevrolet 2500HD 4x4 Duramax/Allison. 2009 Heartland Big Country 2950RK 5th wheel,prodigy controller, 18k Reese signature series hitch, Line X bed liner
Turd Herder
A strange place
Power Stroker wrote: Turd Herder wrote: Flattop wrote: Goodyear Marathons are very, very good trailer tires. Keep them full of air, and as long as you don't pull over 65mph you will be in great shape.
That one sounds sarcastic.
edited 04/06/08 05:00pm by Turd Herder *
2006 GMC LBZ Crewcab
2008 Jayco Eagle 345BHS
14k Superglide w/Superrails
ol Bombero-JC
pitch black wrote: forgot to tell, the tires are size 16, load range E, and 80 psi max
PB - that's interesting! (load range "E" and 80#).
Previously, Marathon = ST (235/80 R 16) "D" tires @ 65 psi.
Are your Marathons ST or LT tires? Load capacity?
Maybe GY is finally catching on!
JC
pitch black
newport, TN
ST 235 80r 16
ol Bombero-JC
pitch black wrote: ST 235 80r 16
Still the same question - side of the tire, load capacity?
(Ex: my 235/80 R 16 "D" rated Marathons were 3250)
scooter4
Sunny S. W. Florida
Turd Herder wrote: Power Stroker wrote: Turd Herder wrote: Flattop wrote: Goodyear Marathons are very, very good trailer tires. Keep them full of air, and as long as you don't pull over 65mph you will be in great shape.
I hope you're right. I just picked up my right and it has Marathons... Made in China.
Not if you are in my shoes. I had seven GY Marathons disintegrate in two years, the pressure was always at #80 and the weight was #2500 per tire with steel valves. For the last two years I have been running Michelin XPS Ribs and haven't had a problem since. It is possible the GY's I had on my 5er were made in China and running them on the hot Florida roads could have mad it even worse. So if you think this sounds sarcastic, think again.
