RV.Net Open Roads Forum: Dinghy Towing: Towing 2008 Jeep Wrangler JK
Search only in Dinghy Towing
 > Towing 2008 Jeep Wrangler JK
Scott9413
New Orleans
Posted: 04/06/08 09:26pm Link  |  Quote  |  Print  |  Notify Moderator
I am preparing to order the parts to tow my new 08 4D Jeep wrangler behind my motor home. I have identified at least that prefer to use a Raodmaster bar and am searching for an appropriate mounting bracket base plate to attach to the Jeep that will be the least visible when not towing.
Roadmaster shows two versions for my stock bumper JK without elect. front sway bar disconnect, an MX model #1428-3 and an XL model
#1428-1. Both have the same price and looking at the online install directions they are both identical installs.
Can anyone provide any input to help with my decision?
Scott
2006 Jayco Seneca HD 35GS
2004 F250 Crew Cab (for sale)
Chief45
Porterville, Calif.
Posted: 04/06/08 09:55pm Link  |  Quote  |  Print  |  Notify Moderator
I don't recall my Md# but I have the roadmaster bracket that is non-visable when you remove the pins.
Good set up.
Their tec support is great if you give them a call.
Scott9413
New Orleans
Posted: 04/06/08 10:27pm Link  |  Quote  |  Print  |  Notify Moderator
After a little more research I think I have found the difference between the two brackets. I believe the difference is that the MX is for motorhome mounted tow bars. Since I will be using a motor home mounted Falcon 2, I think the MX should be my selection. Any input?
wilanddij
CA Desert
Posted: 04/06/08 10:50pm Link  |  Quote  |  Print  |  Notify Moderator
Very good advice is available from billarf. You can view his ongoing topic on towing JK Wranglers at this link JK Tow.
Will & Di
2004 Southwind 32VS
Workhorse/8.1
Jeep Wrangler/Blue Ox
"We have met the enemy, and he is us" Pogo
