RV.Net Open Roads Forum: Fifth-Wheels: Anode - Suburban water heater
 > Anode - Suburban water heater
Rock2
PA
Posted: 04/09/08 08:36am Link  |  Quote  |  Print  |  Notify Moderator
Our camper has been winterized since last late fall for the winter. This Saturday I plan to open our camper to get ready for the spring. We have 2007 Cameo made by Carriage. We have 10 gallon water heater made by Suburban that comes with gas/electric and DSI. Now I have a question about anode. I plan to insert the anode back in the water tank. Do I need to put Teflon tape and few drop of mineral oil on anode tread before I insert? Thank you.
goin2themountains
Aztec, NM
Posted: 04/09/08 08:38am Link  |  Quote  |  Print  |  Notify Moderator
If most of your anode still exists, yep, put it back in. Teflon tape will help removal next fall. YMMV. Have a great camping season.
Puller: '04 HD2500 4x4 SB,EC Duramax/Allison. Airaid intake, 4in. exhaust turbo back, ORU leveler.
Pullee: '02 Keystone Cougar 276EFS Reese 16k w/ slider.
(map is for current 5er only)
ACZL
UPstate,NY
Posted: 04/09/08 09:07am Link  |  Quote  |  Print  |  Notify Moderator
Plus the tape will help seal up on the threads. As a thought, flush out tank before installing the rod. be surprised as to how much******comes out. What does the mineral oil do?
2003 F250 SD,CC,4x4,SB,AT,Lariat,6.0PSD
2006 Cedar Creek Silverback 33 LBHTS "Custom"
Member of The Cedar Creek RV Club
"Creekin' in the Summer"
"The best part of RVing and Snowmobiling is spending time with family and friends"
"Catin' in the Winter"
Rbrunson
Tangent, Or.
Posted: 04/09/08 11:30am Link  |  Quote  |  Print  |  Notify Moderator
Makes it slippery. Works good on lots of things.
Dodge Quad Cab Cummins turbo diesel 3500 4x4 5-speed. U.S. Gear exhaust brake, 1500w inverter, 115v onboard air compressor.
'07 Mobile Suites 36 SB3 #3424
stripit
Clinton Twp, MI
Posted: 04/09/08 05:52pm Link  |  Quote  |  Print  |  Notify Moderator
I read that you are NOT supposed to use the tape, as it makes a barrier and stops the conductivity of the rod to the tank. Makes the rod ineffective. It needs to make contact to work.
Stacey Frank
'04 Mobile Suites 36 TK3 #1341
'99 Int'l 4700 Lo Pro MDT
'04 PT Turbo
'Direcway satellite
Rod Wise
Malvern, OH, USA
Posted: 04/09/08 06:09pm Link  |  Quote  |  Print  |  Notify Moderator
stripit is correct, you should use pipe thread compound, not Teflon tape. Might want to check your electric element too. Just had to replace mine, unit is 4yrs old; it was half gone/ate up. Flush tank really good also.
Rod & DeeDee Wise
Good Sam Charter Life Member,IRV2,American Legion,Eagles,RV.Net
07 Chevy SRW 3500,4x4,D/A,ext.cab
04 Everest 343L
facory
Mineral Bluff, GA
Posted: 04/10/08 07:16am Link  |  Quote  |  Print  |  Notify Moderator
What is a good process for flushing out the hot water tank? I replace the anode rod annually whether it needs it or not. They're cheap and easy to replace. I have never actually flushed out the tank though.
Fred Cory
Mineral Bluff, GA
2008 20' Cruiser RV Toy Hauler
Dodge Durango 5.9L
Harley 06 VRod
Rock2
PA
Posted: 04/10/08 07:26am Link  |  Quote  |  Print  |  Notify Moderator
I have received a message from Suburban and said they recommended to use teflon tape. I remember somewhere they mention about compound. They said not to use compound because it will froze the tread and hard to remove anode. So I do not know if this information is correct or not?
08f450psd
Westminster, Maryland
Posted: 04/10/08 07:30am Link  |  Quote  |  Print  |  Notify Moderator
Limit to 1, or at most 2, turns of teflon tape. You will still get electrical connectivity through the tape.
Rock2
PA
Posted: 04/10/08 08:40am Link  |  Quote  |  Print  |  Notify Moderator
Posted By: facory on 04/10/08 09:16am
After you remove the anode, turn the water faucet on and let it runs few minutes. It will flush out sediment.
