PatricioFamily
Eastern NC
Does anyone know.... Its it ok to go to the weigh station that tractor trailer trucks use to weigh? We have been thinking about going to a place like this to weigh our truck, then weigh the truck and 5er just so we can know for sure what our weights are. Does anyone know anything about this. Is it ok? Would it work? Is it a good idea? Whatcha think? Thanks...The Family
hotrod4x5
Fulltiming Southwest USA
If it is open, I doubt they will be happy about you pulling in, they will likely wave you through, and not give you time to weigh, or even ask if you can weigh. Some don't have gates and some have the scales always on, I guess then it would be ok.
Rodney 2005 Laredo 29GS 2002 F250 V-10 Hughesnet Satellite Internet
carrollti
Sumter, sc
You can go to a truck stop that has a CAT scales.
TC
hotpepperkid
Chino Hills CA
hotrod4x5 wrote: If it is open, I doubt they will be happy about you pulling in, they will likely wave you through, and not give you time to weigh, or even ask if you can weigh. Some don't have gates and some have the scales always on, I guess then it would be ok.
Some flash you your weight as you pull each axal on to the scales
hpk
2000 Ford F-350 SRW 4X4 PSD Jayco Super Lite 29.5RKS 5th wheel 50 gal X-ferflow in the bed tank. Banks big exhaust and Stinger kit.
jlnix
Georgia
I believe your questions related to using the scales at truck stops and, yes you can use them. A truck driver friend of mine told me the Cat Scales were considered the most accurate. There is a fee (about $16 I think). Try to pick a time when no trucks are waiting and go in the scale house and ask about their procedure. You should weigh the rig full of fuel and all the stuff you take with you, then go to the back of the lot, take the camper off and weigh the truck by itself.
1992 Avion 35.5 5th Wheel
2006 F-350 King Ranch
6 liter PSD Torqshift Tow Command
bldrbuck
Boulder, Colorado
Your local moving company, gravel company or garbage compony will have a scale and probably weigh your unit either free or for a small fee. Weigh stations don't usually accept RVx/
93 Ford F350 Turbo Diesel, DRW, Crew Cab. PullRite Hitch. 90 Nomad 28' 5er, 375 Watts Solar, 2800 Watt Yamaha Generator, 1750 Watt Inverter, 4 Trogan T105 Batteries, Spare tire and wheel and folding ladder. Me, wife and 2 spoiled Maltise furkids.
bldrbuck
Boulder, Colorado
hotrod4x5
I thought he was talking about road side weigh stations... ? If not, then yes, you can use the scales at truck stops. I have several times. You pull onto the scale, put your front axle, rear and trailer axles on different scales, pick up the phone and talk to the nice lady. She will ask for your company name and truck number, just tell her you are an RV and give her your name. It usually costs 8-10 bucks with a free re-weigh. You can drop your trailer and reweigh the truck if you like.
donn0128
Pronounced Ore-gun
Here in Oregun I do it all the time as long as the scales are closed. They normally leave the scales turned on and just close the office. I can always get the weights.
Donn
enblethen
Moses Lake, WA USA
The majority of the state weigh station now have electronics scales. They can be used 24 hours a day as Donn)128 stated.
I use them more than normal to check loading.
When they are closed is the best time. Gives plenty of time to weigh each corner front and back as well as toad in my case.
I log in how much fuel, water and grey/black tank levels.
Bud
Suzuki XL7 pushing Pace Arrow
