RV.Net Open Roads Forum: Toy Haulers: battery
Search only in Toy Haulers
 > battery
blasterx2g
casselberry , fla/seminole county usa
Posted: 04/10/08 09:33am Link  |  Quote  |  Print  |  Notify Moderator
i just bought a new RV battery for my 03 wanderer wagon because the other one seemed to die. There still isnt any battery power once i turn the electric off. Is there a fuse or switch somewhere?
enblethen
Moses Lake, WA USA
Posted: 04/10/08 09:45am Link  |  Quote  |  Print  |  Notify Moderator
Could be one adjacent to battery or in the converter panel.
Bud
Suzuki XL7 pushing Pace Arrow
jtgroover
Hooliville #645
Posted: 04/10/08 11:30am Link  |  Quote  |  Print  |  Notify Moderator
you got the leads on correctly? + to +, - to -
Git-R-Dun
Broccoli1
Los Angeles
Posted: 04/10/08 02:15pm Link  |  Quote  |  Print  |  Notify Moderator
You bought a new battery because you lost 12v power???
06 F250 V10 SB 4x4 Gulp Gulp
WW FSC2800
Rincon 650, Rhino
Power Wheels 750
"Shoot, I'm the world's best backwards driver!"
beemerphile1
NE Ohio
Posted: 04/11/08 06:45am Link  |  Quote  |  Print  |  Notify Moderator
You aren't really giving much information to work with. There might be a disconnect switched off, might be a broken wire, might be a fuse, might be something else entirely. You will need to use a meter or test light and track down where you have power and where you don't. You should be able to read power at the battery, then check at the cable connections to the converter/inverter. Wherever you find that the power does not exist, backtrack between there and where it does. The ground terminal of the battery should have a good solid connection to the frame located near the battery. Everything else in the trailer will also be connected to the frame at some point. Post back with any more questions and let us know what you find.
Tim
"Okay, I admit it, the only thing I'm really good at is being me."
Support the "No Child Left Inside Act"
2006 Weekend Warrior FK1900
1998 Ford E150 4.6L
1996 BMW R1100GS
2005 Trek Madone 9spd.
1995 Burley tandem
ToyzRGood
Edgewater, FL
Posted: 04/14/08 06:45am Link  |  Quote  |  Print  |  Notify Moderator
Mine runs through a resetable Bussman circuit breaker before going in to the converter. This blew on me several months ago and I went crazy until I figured it out. Follow your + wire from the battery and look for a circuit breaker. If it is the manual resetable type their will be a very small reset switch on top of the breaker that you must push in to reset. Hope this helps!
* This post was last edited 04/14/08 07:17am by ToyzRGood *   View edit history
2003 Silverado 2500 HD EXT Cab 6.0L Reese 15K
2006 Thor Wild Thing 28SG-M5
1988 HD Electra Glide Sport
2002 Yamaha Roadstar
2002 Suzuki Telefonica GSXR
 > battery
