Johng
Gilbert, AZ, USA
I had a similar problem and found that the main door was not closing all the way, on my MH there are two positions, DW wife could pull in on the main door while driving and the rattle would stop. The main door was not closing all way against the screen door. Worked, might give a try.
Happy RVing
John and Judy
US Air Force - Retired
05 Beaver Santiam 40DST
08 Malibu Toad/Brake Buddy
Bronco4me
Ridgecrest, CA
Weather stripping...and many times a folded paper towel.
Bronco
1992 Holiday Rambler Aluma-Lite 33CSXS
2005 Yukon Denali
1990 Bronco XLT Fishin' wagon
pingpong
Quote: DW wife could pull in on the main door while driving and the rattle would stop. The main door was not closing all way against the screen door. Worked, might give a try.
Wow! She must really have strong muscles...do you make her keep holding it for the entire trip so you don't hear the rattle?
JK...actually we've experienced the same...off and on...thought it was the rattling of the slide locking arms...but now will have to do a little more investigating. Thanks for the post and thanks for the replies!
Husband, Wife, 2 kids, 3 cats
2007 Newmar KSDP 3910
2007 Jeep Liberty
"Whenever I feel blue, I start breathing again!"
"How is it one careless match can start a forest fire, but it takes a whole box to start a campfire?"
Nerraw and DW
Texas for now
driveby wrote: it is a rattle or squeak? foam works for rattles but I'm battling a squeak. Darn I5!
Our squeeky door was driving us nuts. I could hear it even with ear plugs in. DH sprayed the door seals with slide lubricant and so far so good.
The rig: 41' 2008 Monaco Diplomat SKQ
The toad: 2008 Honda CRV EX-L
The Pilot: Warren
The Navagator: Betty (recalculating!)
The Passengers: Bear and Sassy (our cat kids)
Home is where we park it
Busskipper
Arnold,Md
deerhntr wrote: I have a 2008 Newmar Baystar with approx 1000 miles on the unit. The unit is equipped with the standard screen door found on most motorhomes and travel trailers. As you all know, this screen door captures in the solid door when opened and closed. The latch that captures the screen door does not have any adjustment to tighten that capture or prevent the door from rattling in the door frame/jam while driving.
I was wondering has anyone has come up with any unique ways of "quieting" the rattle these screen doors produce while driving. One thought I had was to install some foam weather strip around the screen door jam to absorb the rattle. Any other thoughts? Thanks in advance.
Russ F.
Kutztown,PA
Lots of good advice, the little stick on dots have worked in the past for me, if you are really desperate you can cut and use the smooth half of Velcro and if you still have a problem add the other side to hold it tight in a few spots.
Like I said the small felt dots will usually solve all my squeaks.
JMHO,
Busskipper
Maryland/Colorado
Travel Supreme 42DS04
MDX-FMCA--M&G Brake
States traveled in this Coach
jeepfreak
Hanover Ma.
I had the same problem with our screen door and what I did was unscrew the rubber bumpers on the main door and put a spacer ( I used a 1/4" nut) between the bumper and the door moving the bumper out. Now it's quiet.
2007 Allegro 34wa Workhorse 8.1, Allison 6-speed. Bow Tie powered 79 CJ-7 TOAD
r1chy
Fairfax, VA
I took our screen door off. I tried readjusting it a few times, but the rattle combined with the occasional having to open it when it didn't open with the main door got to be a real pain in the 4SS - so I just did away with the problem by taking it off.
Simple procedure, just took it off at the hinges and I don't miss it a bit.
R1chy
Fleetwood Revolution - 2002
RamblerCat
Freeland, Michigan
I win for the best White Trash solution..... My extra pot holder!! I slam it in the door at the top corner, waaaa laaah, no more rattle!
1987 Holiday Rambler Imperial Limited 40' Cat/Allison Pusher
Bronco4me
Ridgecrest, CA
RamblerCat wrote: I win for the best White Trash solution..... My extra pot holder!! I slam it in the door at the top corner, waaaa laaah, no more rattle!
I thought my paper towel was pretty low rent too.
PCAracer
Oklahoma
Ok, I had a similar rattle but it was not the door itself as the rest of you have experienced. We could put our hand on the door while driving and the noise would persist. We found it was comming from the top folding hinge, not the piano hinge but the one at the top that is a folding arm to controll or limit the door travel. When the door was closed and it was folded up it was a little loose and would just sit there and rattle to beat the band. I took a piece of my wifes hair elastic for pony tails? and wedged it between it and it stopped. I felt good that day I can tell ya...
2005 Newmar Kountry star 3910
Spartan Chassis with ISC Cummins 330 Hp
