RV.Net Open Roads Forum: Travel Trailers: Unit dry weight or curb weight?
 > Unit dry weight or curb weight?
Roadhouse66
Sanford, MI
Posted: 04/11/08 01:19pm Link  |  Quote  |  Print  |  Notify Moderator
Not sure if this is true, so hopefully you guys can answer it.
I always thought the unit dry weight listed for a camper was completely empty and dry. The place we bought our TT from said the listed weight for dry units actually includes your propane tanks full and fresh water tank full......is this true? So my camper has an advertised dry weight of 68XXlbs. So with the fresh water tank empty and propane tanks empty it would truly weigh 64XXlbs.
I've also heard the advertised curb weight of a TV is with the gas tank full....is this true?
TIA
'07 Hornet 30BHS TT-family cabin
'94 Suburban 2500 tow rig w/454ci, 4.10 gears, Prodigy controller
'95 Jeep Grand Cherokee-8"lift, 37" tires-play toy
acadianbob
St. Paul, MN
Posted: 04/11/08 01:27pm Link  |  Quote  |  Print  |  Notify Moderator
Well I think that is incorrct information they have given you. The dry weight on our trailer (from the brochure) did NOT include any fluids, spare tire, options. etc. There should be a sticker in your trailer with the actual out-the-door vehicle weight. Maybe in a cabinet in the galley area. Ours weighs 500 pounds more than the brochure dry weight. Brochure 4,000 pounds, factory sticker 4,500 pounds, plus fluids and personal items.
Bob, Wendy,& Spanky the Fox Terrier
F150 FX4 5.4L 3.73's
Surveyor 235RKS
Reese Straight Line
Prodigy
skipnchar
Topeka Kansas USA
Posted: 04/11/08 01:31pm Link  |  Quote  |  Print  |  Notify Moderator
Don't confuse "DRY weight" with "empty" or "unloaded weight". Dry weight just means with no liquids and MOST companies don't use t his. Most list "UVW" or "Empty" weights in brochures and this is the basic trailer with no options, either forced or selelcted AND no consumables aboard. The UVW will never been seen in a trailer that is in use. Dry weight COULD be seen but it would be pretty rare to drag around an unusable trailer.
fulltimin
Home is where we Park It.
Posted: 04/11/08 02:24pm Link  |  Quote  |  Print  |  Notify Moderator
Go and look at the weight sticker inside one of the cabinets. Most of the ones I have looked at do not include the weight of the propane, nor the weight of the water in the fresh water tank, when giving the UVW. Most I have looked at looked similar to this.....
Also, truck weights do not include but a couple of gallons of fuel, and are a stripped down version. If you add a diesel engine, and other accessories, then the weights are not accurate.
Dave
If momma ain't happy, ain't nobody happy....
Shower head mod to conserve water.
Pete D
Washington
Posted: 04/11/08 02:35pm Link  |  Quote  |  Print  |  Notify Moderator
The OM for my Ford Ranger sez "² Base Curb Weight : Weight of the vehicle including any standard equipment, fluids, lubricants, etc. It does not include passengers or aftermarket equipment."
I read that as full fuel tank and any factory equipment.
My experience leads me to believe that many of these definitions can vary from manf to manf, esp in trailers.
1998 Ranger 4.0 4x4
1991 Scamp 13'
mwebber78
New England
Posted: 04/11/08 02:40pm Link  |  Quote  |  Print  |  Notify Moderator
Forest River products are notorious for low dry weights. Some companies are right on. Aerolite and Kodiak weigh every trailer after it's made and put the sticker in the cabinet.
So basically they do whatever they please and it will vary from company to company.
MOST companies when using the UVW on the sticker inside the cabinet are "as built". When listing the number in brochure's it is usually for a trailer with NO options and dry.
My Sunnybrook stated a specific number in the brochure, the UVW posted in the cabinet is 400lbs heavier - I added options and that adds weight.
Michael
2 DD's and my DW
6 Acre's of Maine
2009 Crossroads Cruiser CF31SB
2008 Chevy 2500HD Ext. Cab LT 4X4
Champion lil' yellow Chinese genset, 4000W
Camping Pictures
Roadhouse66
Sanford, MI
Posted: 04/11/08 09:03pm Link  |  Quote  |  Print  |  Notify Moderator
The weight in the catalog/brochure and inside my cabinet door are only about a 100lbs different. It was the weight inside the door that the dealer told me included a full fresh water tank, and full propane. Thanks for the help.
Pete D
Washington
Posted: 04/11/08 09:20pm Link  |  Quote  |  Print  |  Notify Moderator
I liked the label I saw on Lance truck camper; not only gave the dry weights, but gave the likely weights of the water and LP, based on the capacities.
For a long time, the small fiberglass TTs had understated dry weights of 950 lbs; I presume there was something magic in being under 1,000 lbs (could be titles). Sadly, it tempts folks who are looking for something to tow with small car/SUV/golf cart or whatever. The weights now are more realistic for the ones still being manufactured.
sbingham
Payson, AZ
Posted: 04/11/08 11:38pm Link  |  Quote  |  Print  |  Notify Moderator
Let me give you a typical example:
1-Dry weight. (A lie advertised in brochures) . . . .4567
2-Delivered weight. (A lie found pasted inside a cupboard or inside panel). . .4960
3-Delivered weight with accessories (getting closer to the truth - but not stated) . . . 5200
4-Loaded with water, propane, tools, batteries, food, solar panels, sat, and camping gear . . .6200
My CAT weight fully loaded for a week was 12,900 pounds with a dry weight trailer of 4567 (Nash 25S) and a curb weight of my Surburban of 5860. Somehow we added 2,500 pounds! Remember curb weight means without gasoline, passangers, and your hitch assemply. It all adds up fast and most folks don't have a clue.
Steve and Bobbie (and Shotgun - my 115 lb dog)
Down sized to a Nash 25S
My web page is www.dustylens.com
Pete D
Washington
Posted: 04/12/08 12:17pm Link  |  Quote  |  Print  |  Notify Moderator
Looking something up for another RV group, I ran across this statement in the Owner's Manual for a 2007 Ford Escape:
"Base Curb Weight – is the weight of the vehicle including a full tank of fuel and all standard equipment. It does not include passengers, cargo, or optional equipment."
