RV.Net Open Roads Forum: Folding Trailers: Fleetwood propane quick disconnect
 > Fleetwood propane quick disconnect
DanMistyMiller
Greenfield, Indiana
Posted: 04/13/08 05:29am Link  |  Quote  |  Print  |  Notify Moderator
Can the propane quick disconnect on the side of my Fleetwood be used with a Coleman camping stove? I believe that it was origionally intended to be used with the indoor/outdoor stove.
traywolf
PA
Posted: 04/13/08 05:56am Link  |  Quote  |  Print  |  Notify Moderator
What year and model trailer do you have?
"Man learns from history, That man learns nothing from history"
2000 F-150
2003 Coleman (fleetwood) Carmel
MrPressure
Posted: 04/13/08 06:09am Link  |  Quote  |  Print  |  Notify Moderator
No. Typical Coleman stoves are regulated to 15 psig. Typical quick connect on PUs are 0.4 psig.
snowman610
Winona MN
Posted: 04/13/08 07:35am Link  |  Quote  |  Print  |  Notify Moderator
Some of the quick disconnects on the sides of fleetwoods are considered high pressure takeoffs and should work.
2008 FleetwoodE4
2005 F-150 with mods
2006 Can-Am Outlander Max
Winona,MN
MrPressure
Posted: 04/13/08 07:57am Link  |  Quote  |  Print  |  Notify Moderator
I'm under the impression that the regulated high pressure (16 psig per their manual) on the side of some FFTs has a #600 or 'disposable' thread (1"x20) and not a quick connect.
If it was intended for indoor use it's low pressure (0.4 psig or 11"wc) A standard.
snowman610
Winona MN
Posted: 04/13/08 09:09am Link  |  Quote  |  Print  |  Notify Moderator
Yup thats it! I knew there was a difference in the couplers (I think my brain took the weekend off)
Beacher
Long Beach, CA
Posted: 04/13/08 10:45am Link  |  Quote  |  Print  |  Notify Moderator
All RV quick disconnects are low pressure.
The high pressure connection found on new Fleetwood PopUps, (and 2004 and earlier Grand Tour models), is NOT a quick disconnect. The connector has the 1/2-20 threads found on disposable propane cylinders.
Some people have used the low pressure feed to supply propane to their third-party appliances, but it usually involves the removal of the appliance's pressure regulator.
An alternative is to make your own High Pressure feed off of your 20# tank using an adapter such as Stay Flow Plus.
