RV.Net Open Roads Forum: Toy Haulers: Rerouting Raptor Generator Exhaust
Search only in Toy Haulers
Open Roads Forum  >  Toy Haulers  >  Modifications & Accessories
 > Rerouting Raptor Generator Exhaust
yardsale1
Orange County, California
Posted: 04/14/08 10:32am Link  |  Quote  |  Print  |  Notify Moderator
EricRobinson8 wrote:
Before you cut it, the other reason I didn't just do what bstock did is I use the JT's stabilizer bars and I had to route around them. If you are going to ever use them, you might want to put the bend on them
Too late!! Just finished the 180 flip. I have it running with the slide out and up agaist a brick wall as a test. If that does not trap the exhaust and set off the co2 sensors, I should be good to go in an open area.
If I go with the JTs at some later point I will visit the muffler shop.
Thanks for the help.
2007 Keystone Raptor 299MP
Too_Tall_Ford
Reno, NV
Posted: 04/14/08 10:49am Link  |  Quote  |  Print  |  Notify Moderator
I don't have a Raptor or a picture of my solution but what I made was a two piece exhaust stack. When I set up, I slide my pipe around the outside of the generator exhaust. This is a 2" (I think) nipple I cut in half, just the right diameter to fit over the Onan exhaust. It is then turned 90 degrees straight up with a 6' length of pipe. The second piece is a 2" coupler with a 4' length of pipe with another 90 degree elbow up top. Right around the railing on the top of the coach, I welded two bolts to my exhaust pipe. I then wrapped the pipe with some heat wrap. I use bungee cords to tie the top off at the welded bolts. The set up time at camp is maybe 5 minutes with myself doing all the work.
The wife doesn't complain about the exhaust smell and I haven't had any issues with it since I built it about a year ago. You might be able to do something similar.
2000 F350 DRW 4wd CC 7.3l PSD
37" Tires w/ 5.13's
Suncoast 4R100
2007 Host Yellowstone
Democracy is 2 foxes and a sheep deciding on what to have for lunch, liberty is a well armed sheep contesting the vote.
5O'clock
Sacramento, Calif
Posted: 05/13/08 02:21pm Link  |  Quote  |  Print  |  Notify Moderator
I have an 08 Raptor 3612 and too hate the location of the genny exhaust. For about 20-25 bucks I made my own Genturi. Works great for the exhaust but doesn't help the noise. I am going to re-route the exhaust to the other side too. Using my homemade Genturi should address the issue of the co entering through slide seals
01 Dodge Ram 2500 4x4 CTD, Edge EZ, BD Exhaust Brake, Towloc,Pressureloc
08 Raptor 3612DS, Pullrite SuperGlide
05 Polaris Predator 500
85 Harley FXST
"too many weekends.. Not enough beer"
rcchallenger
La Mirada, California
Posted: 05/13/08 03:45pm Link  |  Quote  |  Print  |  Notify Moderator
Y-Guy wrote:
Well I did own a 2005 Raptor 3612 and had my exhaust pipe running where you are planning on routing yours. I had several problems with the detector sounding off since it was leaking in to the cabin. I ended up using a home made Genturie anytime I ran the generator. The dealer even extended the pipe a few inches, but still had it go off. If you re-route it I'd plan on buying or making your own Genturie to be safe.
Keystone moved the exhaust because the bedroom detector was sounding off. I hate mine too and plan to re-route it when I have time. I also like the idea of the Genturie.
2005 Ford F350 XLT 4X4 SRW Powerstroke Diesel Firestone Air Bags
2006 Keystone Raptor 3612DS
2006 Yamaha WR450
2006 Yamaha YFZ450
2005 Yamaha TTR230
2006 Kinroad XT250CC Go-Kart
yardsale1
Posted: 05/14/08 12:36pm Link  |  Quote  |  Print  |  Notify Moderator
I have not had a problem with my detectors going off since I rotated my exhaust 180 degrees. Maybe this is only a problem with the models that have a bedroom slide, who knows. If you look at other brands of rigs, there seems to be no rhyme or reason to the exhaust routing.
This is truely the best mod I have made to the trailer. It makes camping MUCH more enjoyable without an exhaust pipe under the awning.
Hockymom63
Chino,Ca.
Posted: 05/14/08 01:28pm Link  |  Quote  |  Print  |  Notify Moderator
We have the 3612 that has the bedroom slide we dont really have this issue but maybe we dont use the genny as much as most? Sometimes something is going off in there but i think its because the battery has run down.
2005 GMC Sierra 3500 DRW,LT ,Crew cab, Duramax/Allison,Edge,Amp steps
2007 Keystone Raptor 3612DS
2006 Honda 230 - husband
2006 Yamaha 230 - son's
2006 Yamaha 230 - mine
2006 Yamaha 125
2007 Rhino660 SE A few mods
