dickandcol
Central MA
Does anyone know if the jumper harness for the brake controller is standard eqipment on a 07 Silverado 2500HD. Or is it an Option?
I am about to buy a new 07 (leftover) silverado 2500 HD 4x4 and no one at the dealer seems to have any awnsers.Im thinking it is up under the dash somewhere, The truck comes with a hitch and trailering package. The dealer thinks the brake controller will have to be HARD WIRED and I am not too fond of that Idea!!!
I would sure apprciate any imput. Thank Dick R.
kernewek
Calgary, Alberta, Canada
My '06 came with the harness wrapped up inside the glove box, all I had to do was plug it in under the dash on the left side of the steering wheel, and add a fuse to the panel under the hood. I can't imagine that much changed from the '06 to the '07 in that respect
Kernewek
2006 2500HD CC D/A 4x4
2007 Crossroads Zinger ZF27RL
"The most difficult thing in the world is to know how to do a thing and to watch someone else do it wrong, without comment."
Theodore H. White
rowaltonjr
Castle Hayne, NC
My 2004 also had a seperate cable in the glove box. The dealers service dept. should be able to find it if the sales people can't.
nogo
2004 2500 Sierra, 2006 Keystone-Cougar 291EFS 5th wheel
We don't do anything, but we do it real well
RV camped in 49 states, every province & territory of Canada & 2/3 0f Mexico
Scot
Maryland
I know the new body styles have a wire bundle up under the dash to connect your controller into and the is a cable under the hood that will need to be connected. Not sure what the bundle looks like or exactly where to find the end of it but it should be up there.
Scot & Ann
*NEW* 2008 Silverado 3500HD LTZ CC Dually Duramax/Allison
2005 Everest 343L
Hidden Hitch 18k
My Photos
McIrish
WC IL
Maybe this link will help you.
2008 Silverado Z71 crew cab
2009 Sunset Creek 267RL
Equal-i-zer
Wayne Dohnal
Banks, OR.
Quote: Maybe this link will help you. It sounds like GM got rid of the brake controller connection. Another "improvement", right up there with tax simplification. I wonder if GM will ever figure out why their market share goes down?
2009 Fleetwood Icon 24A
LinkPro battery monitor
EU2000i generator
Scot
Maryland
I'm guessing it has more to do with the integrated brake controller and not wanting to have 2 hooked up at the same time so when they make the harness, they just put both in place and hook up what ever you have ordered... But I'm just guessing...
Traveler II
Lindstrom, Minnesota
We ordered the trailer package and the controller came installed.
The 7 plug in bed wiring 5th wheel package that we ordered was not installed and the wiring was behind the bed behind the cab. Also the wiring that would charge the battery in the trailer was not installed. Not sure why they would not hook these thing up when you order a 5th wheel package.
Jim & Jane
2008 Cardinal 30TS
Trail Air Pin Box, Air Suspension, Smartair Air Spring Self Leveling, Reese Signature Series 18K hitch
2008 Chevy Silverado 2500HD 4x4 Duramax/Allison Ext Cab Long box
Use And Promote CB Channel 13
Dale_S
Saugus, CA
Mine is an 07 classic also. There should have been a wiring harness and connector in the glove box with a 40 amp fuse. When I did my controller I bought the harness for the controller that uses the factory plug in under the dash. I used this LINK when I hooked mine up. It is step by step with pictures for the 01-07 Classic body style.
2007 Chevrolet Silverado Classic 2500HD Duramax 6.6
2008 Jayco Eagle 299RLS
Camping Mode
South Carolina
The 2007 new body style does not have a plug or pigtail. There is a bundle of wires under the dash, below the steering wheel. You also need to put in a fuse and hook up two wires under the hood. The hardest part was finding the nuts to hook the wires onto the studs.
I found several articles online about it and the owners manual actually had pretty good instructions. Not as bad as it sounds - took 15 minutes (not counting trip to Wal-Mart for a fuse and digging around in my toolbox for nuts).
Good luck,
David
Camping Mode = Sisters stop acting like sister and become best friends when we camp..."They are in Camping Mode"
2007 Cougar 281BHS
2007 Chevy 2500HD
Me, DW and (2)DD
ALL the animals stay home!
