RV.Net Open Roads Forum: Fifth-Wheels: Need help in Minneapolis area: rather urgent!
 > Need help in Minneapolis area: rather urgent!
donn0128
Pronounced Ore-gun
Posted: 04/15/08 08:13am Link  |  Quote  |  Print  |  Notify Moderator
First thing, call one of those mobile pumps to come out and evacuate the holding tank. Then after it is empty it is a fairly simple job to unbolt the valve and remove it. But be prepared for more crud.
Donn
shutdown
In The Dog House
Posted: 04/15/08 08:39am Link  |  Quote  |  Print  |  Notify Moderator
My guess is frozen. if its been cold the tank heater will heat the tank but allow the plumbing down to the valve to freeze. try some heat tape around the plumbing that is between the tank and the dump valve. Other than that only other thing it could be is that the handle broke off the gate. In which case when you move the handle may pull the whole way out or at least as you pulled and pushed it would feel different.
Cool Canuck
Winnipeg, MB, Canada
Posted: 04/15/08 09:08am Link  |  Quote  |  Print  |  Notify Moderator
This story sounds all too familiar. If your cable or rod is still attached to the valve, the valve is probably opening. Here's the test. Find one of those clear elbow flush things. The one you hook a garden hose on to.
Close all the gray and black valves;
Put the flush elbow on the pipe and put the drain pipe cap on the flush elbow. (so the end is capped and water can't come out.)
Attach a garden hose. (best to have the on/off valve right there handy)
Turn on the water carefully and pressurize the plumbing.
Pull the black tank valve.
You will know immediately whether the valve opened or not.
Shutoff the water and CLOSE the black tank.
I'm betting the valve opens and that you have the nasty mountain.
If that is the case, go to the plumbing store and find one of those balloon things that fit into a sewer pipe and you attach a garden hose to. (beginning to think I has a garden hose fetish.) You should be able to find a short hose extension with an on/off valve in the same section.
Hook up your sewer and open the black tank.
Take Balloon deal with hose attach and place it down through the toilet into the pipe exiting the toilet.
The water pressure will expand the balloon creating a seal in the pipe.
The stream of water will breakup a lot of the mountain and get you going, but you will still have some work to do.
Hope that helps.
00 Jayco Eagle 313 5th
01 F250 PSD S/C S/B
Barbilou and Fujimo
St. Cloud, Minnesota
Posted: 04/15/08 09:38am Link  |  Quote  |  Print  |  Notify Moderator
OK, the valve IS open, just can't get anything to move. A friend is en route with a snake and a hand pump. Can't do much at the toilet end until we get the level down. Thanks all for your time. Will be at this for many hours.
Full Time since November 05!
'04 Cherokee M315L 2 slides Fifth Wheel
'05 Chevy Silverado 2500 4X4 Duramax Diesel,crew cab,long bed
Eliminator ELM-3600SS generator
Barb's RV Dreams Articles
ford truck guy
Pennsylvania
Posted: 04/15/08 10:33am Link  |  Quote  |  Print  |  Notify Moderator
I second the turning of the rod clockwise, sometimes they loosen up during travel.
Joe and Lori
2005 Ford F250 SD 6.0
08 Montego Bay
Cool Canuck
Posted: 04/15/08 11:39am Link  |  Quote  |  Print  |  Notify Moderator
Believe me, the drain cleaning bladder will take out the mound. With very little mess. Poking around with awning hooks, snake and whatever else has limited success. A Drain Cleaning Bladder will seal the pipe and then direct a sharp stream of water. You can find these at Home Depot and the such. They come in different sizes. 1 1/2 - 3 inch and 4 - 6 inch. If I recall correctly, the waste pipe is 3". This is the voice of experience.
weekendrvers
Iowa
Posted: 04/15/08 11:45am Link  |  Quote  |  Print  |  Notify Moderator
I hope you got it Draining Let us Know how it went? ~`Good Luck you got a lot of great advice here~~Sandy
New Everest Owners~~~
Steve, Sandy, Katie and Our Cocker DJ
took delivery waiting for Spring to take her out now!!!
2007 345S
2008 Ford F350 King Ranch Diesel CrewCab 4x4
riddellr
Belleville, IL, USA
Posted: 04/15/08 01:36pm Link  |  Quote  |  Print  |  Notify Moderator
We had a similar problem with a young teenager and flushable wipes We now use a "Flush King". With the flush king, you can close the valve on it, then open your black water valve and force water into the Black Tank using the garden hose attachment on the Flush King. It took several attempts to get all the wipes out, but once cleared, the tank worked fine again..
AUWing
Slinger, WI
Posted: 04/15/08 01:52pm Link  |  Quote  |  Print  |  Notify Moderator
Not sure how familiar you are with the area but there are a lot of dealers along Hwy 10 around Elk River. No doubt there are experts in one of those buildings.
I'm betting a freeze-up at the valve is the likly culprit
From someplace in SE Wisconsin
2006 Silverado 2500 Ext-cab / reg box / D/A
2006 Jayco Eagle 325BHS
2001 Goldwing, Cyclemate trailer and a tent (to remind me why we have the Jayco)
1999 BMW 1200C (007 bike) too cool to part with
MNtundraRet
Bloomington, MN
Posted: 04/15/08 02:03pm Link  |  Quote  |  Print  |  Notify Moderator
If the metal rod is threaded, it should just screw back into the gate. Mine came unscrewed on my last trailer, and that was all that was needed.
Mark
Mark & Jan "Old age & treachery win over youth & enthusiasm"
2003 Fleetwood Jamboree 29
