RV.Net Open Roads Forum: Towing: prodigy brake controller question
Search only in Towing
Open Roads Forum  >  Towing
 > prodigy brake controller question
Muskoka
Barrie, Canada
Posted: 04/15/08 04:18pm Link  |  Quote  |  Print  |  Notify Moderator
Just installed my prodigy v2.6 brake controller in my 02 Chev silverado.
My question is it normal to have the 'dot' lights stay on which means it is powered all the time? I used the proper manufacturer harness and I believe I have it installed correctly.
I am concerned because on my F-150 the same brake controller shut off everytime I shut off truck's ignition and with the truck ignition off the unit stays on now in my Chev.
Are Chev's just different or have I missed something in the install.
I lost the manual and am just throwing this out for other prodigy users to comment.
Many thanks
2007 Rockwood Roo 21SS
downtheroad
Puget Sound
Posted: 04/15/08 04:22pm Link  |  Quote  |  Print  |  Notify Moderator
Normal... at least for mine.
Probably by the time you go back outside and check on it, the "dot light" will be out.
Takes about 15 min. with no brake activity.
GMC Duramax/Allison (LBZ)
Komfort 277TS Our Rig Pic
Reese Dual Cam HP
hotrod4x5
Fulltiming Southwest USA
Posted: 04/15/08 05:25pm Link  |  Quote  |  Print  |  Notify Moderator
Yup, it's normal. As soon as you hit the brake pedal it is on. And it will stay on until you leave it alone for some specified amount of time (15 min?). I would say that the one in you F150 was wired improperly.
Rodney 2005 Laredo 29GS 2002 F250 V-10 Hughesnet Satellite Internet
rhillx4
Huntington Beach ,CA
Posted: 04/15/08 06:08pm Link  |  Quote  |  Print  |  Notify Moderator
Its normal. Ours stays on for quite a while I would guess at least 15-20 minutes after shutting off vehicle and walking away.
2002 Dodge Ram 1500 Quad-Cab
2008 Jayco JayFlight 26BH
b_salgado
Salisbury ,NC,USA
Posted: 04/15/08 06:30pm Link  |  Quote  |  Print  |  Notify Moderator
My Prodigy stays on for 15 min in my F-150. As soon as the brakes are tapped it comes back on. Normal
04 Lariat Supercrew 4x4,5.4,3.73, Edge tuner, flowmaster duals
06 Trail Bay 31BH, nicely optioned
Equal-i-zer
Prodigy
Follow vehicle, 05 KIA Sorento EX for the golden retrievers.
