RV.Net Open Roads Forum: Travel Trailers: Rockwood Water Hookup Question
 > Rockwood Water Hookup Question
mflanagan
WI
Posted: 04/16/08 07:51am Link  |  Quote  |  Print  |  Notify Moderator
I have a Rockwood 2602 and I have a question about the water system. If I hook up to the city water connection, does it fill the fresh water tank or does it bypass it?
I want to make sure when Im at a campground hooked up to city water that I'm not taking on an extra 25 gallons of fresh water in the Potable tank and not know it.
Thanks!
Flan
1997 Izuzu Trooper
Equalizer Hitch, P3 Brake control
2005 Rockwood 2602
windriderjr
Massachusetts
Posted: 04/16/08 08:02am Link  |  Quote  |  Print  |  Notify Moderator
I don't know about your exact TT, but there are usually two seperate places to put water, one labeled "City Water" that your hose can screw onto and that other being a hole without a threaded connector that you use to fill the fresh water tank. If this is the case, the city water will not reach your fresh water tank. There is a check valve that prevents that from happening.
DW and I in our Gulfstream Amerilite 21MB
Chevy Silverado 2500 HD - Duramax Diesel 6.6L - Allison Tranny
"We can categorically state that we have not released man-eating badgers into the area." - Major Mike Shearer - British Army - Basra, Iraq
mflanagan
WI
Posted: 04/16/08 08:32am Link  |  Quote  |  Print  |  Notify Moderator
Great! Thats what I wanted to hear. I dont want to inadvertently fill up my Fresh water tank when hooked up to city.
Thanks
Flan
Hornet28BHDS
Parker, PA
Posted: 04/16/08 02:24pm Link  |  Quote  |  Print  |  Notify Moderator
It bypasses that freshwater tank.
2006 Hornet 28BHDS-Bunk House, Dual Slides
2006 Dodge Ram 2500 HD
5.7L Hemi, Factory Towing Package
Reese Brake Controller, WD Hitch and Sway Bar
Life is short, why not spend it in an RV!
SPRING HAS SPRUNG!
o2bpadln
Richlands, NC
Posted: 04/16/08 03:36pm Link  |  Quote  |  Print  |  Notify Moderator
I have a 2602. The city water hookup is on back of tt. The fresh water fill up is on left side @ rear. The two do not connect.
o2bpadln
03 Chevy 1500 5.3 Towing Package
04 Rockwood 2602
Have road will travel. Have water will paddle.
