BackroadNiagraFamily
Phoenix AZ
Has anyone found any value in putting Reflectix Foil Insulation under your mattress(es) to reduce cold air seeping in through the wood?
Thanks for your time.
pupcamper
Van Buren, Arkansas
I haven't done it but some of the people on Popup Explorer have and they swear by it.
Happy campin'
Mitch
Wife, daughter, son, a new son (son- in- law) and two campin' dogs.
2004 Coachmen Clipper
1999 Ford F150 XLT
Camping is as close to Heaven as you can get.
CEK0515
Near Tahoe National Forest
We have it under our mattress and we made inserts of the windows on the bunkends. We notice a difference.
outofd
Snoqualmie
they make a big difference under the mattress. first time we did it, I left a small patch undone and wow, very cold. The inserts for the windows also work great and also cut out lights from cars and other campers as well as early sun rises. Also use the popup gizzmos for the tent material over the bunks, you will be warm as toast and use less propane for heating. best wishes, Bill P.S Also used it in windows when it was 103 outside, AC works better and easier.
IrishPam
Cincinnati, Ohio
We refurbished a hardside pop-up a few years back & placed the reflectix on the bunk end wood, then carpeting (new scraps left over from office work) & then our foam mattress. What a difference! It also added a layer of padding as well.
We currently have a TT that has a ton of large windows. They are single pane, so I made window covers using the reflectix. Helps in hot & cold weather as well as keeping the TT darker in the morning. They fit pretty well in the underbed storage when not needed.
Pam, Sharon & Emma
Gabby-waiting at the Rainbow Bridge with Mocha
2002 Yukon XL SLT
2008 Jay Feather 31V
Days Camped in 2008 = 34
retiredtraveler
Woodstock Il --- GO HIKING!!!!
Yes, it helps.....
Pup: 2007 Jayco 1206 w/slide-out + shower
surge brakes, 54w solar panel
TV: 2005 Nissan Xterra 4X4, manual trans
25 years tent camping, 4000+ miles of hiking, lots of biking
Wiscampsin
Wisconsin USA
Quick, easy, effective, relatively inexpensive mod.
2006 Toyota Tundra DoubleCab
2007 TrailCruiser C243S (traded in)
2008 Jayco Eagle 314BHDS
http://community.webshots.com/user/wiscampsin
gonzo71
Edmonton, Alberta, Canada
we got it since 2005 and it works
Daddy..Carsten
Mommy..Leah
Baby..Jewell 10 yrs
2002 Holiday Rambler Vacationer 34SBD, W22 Workhorse, 8.1L Vortec
2006 Piaggio Beverly 250 GT (BV250 in US)
2007 Suzuki Grand Vitara JLX-L (lil toad)
bud121156
Shelby, North Carolina
Donnie and Cheryl
Fleetwood Westlake
spearmint
Midwest
Is it glued down?
